Old 12-09-2010, 06:49   #1 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
N73 PA ic Removing Problem
we have a problem when we trying to remove N73 PA IC we face after removed PA short.tried in so many N73 PCB-s.Result So many PAs are shorted while removing through Hot Air Gun,We did all tries,any one have some special S-Kills,idea to Share?
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post:
Old 12-09-2010, 10:01   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
yes my friend this is a common issue , try to use preheater or heat the pcb in underside.
but if u use ir rework station then u can able to remove PA without damage.
Old 12-09-2010, 10:05   #3 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
any other idea how remove bb5 pa with hot air station.
Old 12-09-2010, 18:47   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
use good flux to melt solder eaisly with hot air gun , but if u have good skill then u can sucessfully remove PA without damage.
I alerady replace more than 200 PA's with hot air gun but now I use ir station to rework.
so do practice in dead sets to improve ur skill .
good luck
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 12-09-2010, 22:02   #5 (permalink)
Member: 1338457
Thanks Meter: 31
just mind ur heater temperatur and make reball all boundary leg using high quality led . then u can fix very easy it. any phone
Old 12-10-2010, 08:14   #6 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
any other guys have also facing this problem.
Old 12-10-2010, 08:27   #7 (permalink)
Member: 698150
Thanks Meter: 23
i have many many problem with pa removing skill
Old 12-10-2010, 10:52   #8 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
which BB5 phones you have Problems???
Old 12-10-2010, 11:01   #9 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
me too same problam,s bat rimove carifully
Old 12-11-2010, 05:26   #10 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
what is the carefull way near you?while removing BB5 phones PA with HOT AIR Gun
Old 12-13-2010, 07:57   #11 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
some times with Hot Air Gun It Works Well,No PA Short after remove.
Old 12-13-2010, 08:04   #12 (permalink)
Member: 698150
Thanks Meter: 23
any video sir please replay its urgent
Old 12-14-2010, 05:38   #13 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
at the moment i think no one have avideo for it
Old 12-23-2010, 06:54   #14 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
some when do care with PCB and with PA it ca be done also with hot air gun
Old 12-23-2010, 06:57   #15 (permalink)
Member: 1475063
i think just cover near conmonent via any metal and heat pa with right tamprature and that's it u have done sucessfully
br
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 08-09-2010 10:20
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.25422 seconds with 9 queries
