Old 01-24-2011, 09:54   #1 (permalink)
Member: 570252
Thanks Meter: 207
Question NEED advice to fix 5310 mic
i realy have a lot of trouble to fix this
i changed too may but i succed in 10% of them
plz help me to 100% succese
what range of temperatue to sold this mic?
Old 01-24-2011, 11:08   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
if u have infrared rework station then u'll able to fix new mic without damage.
but search in this forum u'll find some of solution to fix new digital mic.
for further details u may contact me on sonork
Old 01-25-2011, 01:46   #3 (permalink)
Member: 1477424
Thanks Meter: 320
i....need same solution.....????
Old 01-25-2011, 02:00   #4 (permalink)
Member: 1225482
Thanks Meter: 45
try trace a line sir
Old 01-25-2011, 02:30   #5 (permalink)
Member: 1490299
Thanks Meter: 20
before you reheat the mic module you need to resolder under mic module put led then after that mildly reheat mic
NOTE: don't put a flux dont forget the mic module of 53410express is very sensitive.
post the result...
Old 01-25-2011, 02:37   #6 (permalink)
ralel's Avatar
Member: 405730
Thanks Meter: 184
here is the tip that might help you
before you reheat the digital mic module
put some cover on it,you can use keypad mat as a cover
but before that, you may put a bit of double sided tape between keypad mat & mic
module, so that it would be stable
like this
The Following User Says Thank You to ralel For This Useful Post:
Old 01-25-2011, 03:11   #7 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
forget about all the tips before
it works very easy with just a cheap hotair...
1.) desolder old mic
2.) clean contact pads and resloder cleaned pads (not to mutch, not to less)
3.) see on back side of the mainboard, if there is something like connectors (you have clean backside with no connectors on 5310 board), then use some tape to save it from heat.
4.) now use some flux or soldering paste and fix the new mic on right place.
5.) begin now ON BACK SIDE of mainboard to heat the position where the mic is on other side...
5.) now you will see, the mic will fix it self on right place and you have won!
its realy the eaysest way... try this way and you will no more demage any mic...
but be cearfull when there are some components on backside...
its no problem when there are some capacitors or resistors, ic´s ... thats all no problem... you even dont need to save it from head...
but be cearfull on plastic parts... this parts need to be removed first if you work with hotair in with my technic by heating from backside of pcb.
good luck!
wbr.
hari
ps: @ralel
i need to test your tip on boards where many components on backside... looks also good working..
i teached my methode many technicans and they have 100% success with my methode, because its very easy when no components on backside of pcb.
The Following User Says Thank You to oOXTCOo For This Useful Post:
Old 01-25-2011, 04:03   #8 (permalink)
ralel's Avatar
Member: 405730
Thanks Meter: 184
actual image
ps: @ralel
more info
instead of heating the PCB at the backside
im using this method for almost 5years and all is working
by this method there no other components would be damage
like 2 keypad/UI ic & keypad connector which is placed on the pcb back side
Old 01-25-2011, 04:34   #9 (permalink)
Member: 677606
Thanks Meter: 55
For me to not have a long problem
Why not be able to do this option
Try jumper from the mic than go to board
100% tested no problems with new mic
The better you than to reheat
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.17072 seconds with 9 queries
