Old 05-01-2008, 16:15   #1 (permalink)
ocha_vista's Avatar
Member: 748428
Thanks Meter: 33
Unhappy ...Need best solution for 2626 contact service....
Hi all 2626 contact service pro..when completily power on just showing nokia then going be contact service..flash ok & when in normal mode select at JAf same case with phone put batt (only showing nokia then going be cotct srvice)..so I try many solution from searching in this forum but problem stiil same..
...I'v already removed & changed :
- conector Lcd & other LCD = ..NOT SOLVED..
- sim ics & make jumper =...NOT SOLVED..
- C2000,R2000 & R2205 =...NOT solved....
finally I tried..Reheat flash IC & reball CPU =....NOT SOLVED...
please anybody can help me to fix this strange problem..
best regard
The Following 2 Users Say Thank You to ocha_vista For This Useful Post:
Old 05-01-2008, 17:26   #2 (permalink)
Member: 70916
Thanks Meter: 56
best regard
change uem ic dudeeee
Old 05-01-2008, 17:39   #3 (permalink)
ocha_vista's Avatar
Member: 748428
Thanks Meter: 33
Are you sure sir...? Iam not
have you ever tried for same phone type & same problem..Sir.....??
Old 05-01-2008, 17:43   #4 (permalink)
Member: 722214
Thanks Meter: 8
run self test by jaf and post resalt
find what test is failed
after that ill tel u the solution
self test is the only one solution for find the reson of Contat servie
The Following User Says Thank You to sanathpeiris For This Useful Post:
Old 05-01-2008, 17:55   #5 (permalink)
Member: 70916
Thanks Meter: 56
contact service will appear in only two complants
1 is s/w
2 is h/w
in s/w u have to flash it
other wise u have to chang sound ic
in 2626 power ic,sound ic, charging ic allin one that is uem
so no dout about it
The Following 2 Users Say Thank You to jbbasha For This Useful Post:
Old 05-01-2008, 20:09   #6 (permalink)
Member: 428081
Thanks Meter: 5
2626,2610 Contact Service
Old 05-01-2008, 20:46   #7 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
best regard
After flashing did you unlock it ???
Old 05-01-2008, 21:07   #8 (permalink)
monti_908's Avatar
Member: 18262
Thanks Meter: 160
best way to solve this problem first u erase flash then flash and write good pm unlock and full factory settings post the result
The Following User Says Thank You to monti_908 For This Useful Post:
Old 05-02-2008, 03:40   #9 (permalink)
ocha_vista's Avatar
Member: 748428
Thanks Meter: 33
THANKS REPLAY
I'v already tried...doesnt work..
All software trik by JAF Already tried but prob still same
Old 05-02-2008, 03:43   #10 (permalink)
ocha_vista's Avatar
Member: 748428
Thanks Meter: 33
THANKS REPLAY
Old 05-02-2008, 03:49   #11 (permalink)
ocha_vista's Avatar
Member: 748428
Thanks Meter: 33
Sorry..double post
self test by JAF...All Passed, except LCD test & FLASH CHEKSUM test failed
What this the meaning brother?....
thanks
Old 05-02-2008, 04:21   #12 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
It also occurs from LCD. So first change LCD from an working 2626, if not ok then try to erase full, do full flash(old version to new), write PM and unlock. If not ok then it must be Hardware. May be CPU.
Old 05-02-2008, 04:29   #13 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
do u hav try flashing ??
try do full erase than full flash back and unlock
use repair file
Old 05-02-2008, 05:51   #14 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
THANKS REPLAY
" jbbasha is right, bro the bottom line is if it is not get cleared by software then the problem is in uem"
Old 05-02-2008, 09:11   #15 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
it's uem case.........boc u have try sof. lcd ect. so try rehot uem ic then flash may be u problem will be ok....
100% working solution for 6500s contact service EMINEMGSM Nokia Base Band 5 ( BB-5 ) 55 09-16-2010 13:10
is there a solution for nokia contact service? doonyi Nokia Hardware & Hardware Repair 10 04-07-2009 08:24
final solution for 7250i contact service... xheti Nokia Hardware & Hardware Repair 12 03-17-2009 14:54
??? Final solution for 3310 Contact Service ??? dannyogolo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 02-21-2003 11:39
Page generated in 0.31549 seconds with 9 queries
