Old 01-11-2010, 21:09   #1 (permalink)
Member: 25709
Question N95 blank screen problem
Hi all,
This is no doubt a common fault but I just want to check if you agree before I order a new screen.
Nokia N95
I slid up the screen as normal and noticed that it had some vertical lines and not the usual display, I open and shut the slider a couple of times and then the screen went blank. I can see that the back-light is working, just can't see anything on the screen at all. The phone itself works.
I've tried re-seating the screen ribbon but that hasn't helped.
Do I just need to order a replacement screen or could it be some other problem?
Thanks in advance.
Old 01-11-2010, 22:49   #2 (permalink)
Member: 25709
Right this is quite odd, I removed the battery, replaced it and started the phone. The screen worked for a while then blanked again.
I took the back cover off and a long screw fell out, this appears to be stripped (untouched by me) so won't screw back in place.
Video
http://www.youtube.com/watch?v=3gadIDefI1A
Old 01-11-2010, 23:04   #3 (permalink)
Member: 1151900
N95 problema schermata vuota
prova a sostituire il flat a me e' capitato. ad un'altro ho dovuto sostituire gli emifilter. prova il flat prima di cambiare il display .
Old 01-11-2010, 23:07   #4 (permalink)
Member: 25709
Costa, thanks for the reply but the translation isn't clear.
http://translate.google.com/#it|en|p...l%20display%20.
Old 01-11-2010, 23:13   #5 (permalink)
Member: 1151900
N95 problema Schermata vuota
replaced flat cable.
Old 01-11-2010, 23:15   #6 (permalink)
Member: 25709
Thanks again,
As the screw is loose in the slide, would this be worth buying?
http://cgi.ebay.co.uk/GENUINE-NOKIA-...item53defb27df
Old 01-11-2010, 23:22   #7 (permalink)
Member: 1151900
ok potrebbe essere anche un problema di ic devi provare.
n95 8gb blank screen problem experttelecom Nokia Base Band 5 ( BB-5 ) 1 09-25-2009 09:04
N95 Blank screen Waterdamaged BillSalih Nokia Hardware & Hardware Repair 1 01-07-2009 01:49
n95 blank screen tornado2008 Nokia Hardware & Hardware Repair 11 10-08-2008 00:30
Page generated in 0.19381 seconds with 9 queries
