01-11-2010, 21:09 | #1 (permalink) |
Junior Member Join Date: Mar 2003
Member: 25709 Status: Offline Thanks Meter: 0 | N95 blank screen problem This is no doubt a common fault but I just want to check if you agree before I order a new screen. Nokia N95 I slid up the screen as normal and noticed that it had some vertical lines and not the usual display, I open and shut the slider a couple of times and then the screen went blank. I can see that the back-light is working, just can't see anything on the screen at all. The phone itself works. I've tried re-seating the screen ribbon but that hasn't helped. Do I just need to order a replacement screen or could it be some other problem? Thanks in advance. |
01-11-2010, 22:49 | #2 (permalink) |
Member: 25709 Status: Offline Thanks Meter: 0 | Right this is quite odd, I removed the battery, replaced it and started the phone. The screen worked for a while then blanked again. I took the back cover off and a long screw fell out, this appears to be stripped (untouched by me) so won't screw back in place. Video http://www.youtube.com/watch?v=3gadIDefI1A |
01-11-2010, 23:07 | #4 (permalink) |
Member: 25709 Status: Offline Thanks Meter: 0 | Costa, thanks for the reply but the translation isn't clear. http://translate.google.com/#it|en|p...l%20display%20. |
01-11-2010, 23:15 | #6 (permalink) |
Member: 25709 Status: Offline Thanks Meter: 0 | Thanks again, As the screw is loose in the slide, would this be worth buying? http://cgi.ebay.co.uk/GENUINE-NOKIA-...item53defb27df |
n95 8gb blank screen problem | experttelecom | Nokia Base Band 5 ( BB-5 ) | 1 | 09-25-2009 09:04 |
N95 Blank screen Waterdamaged | BillSalih | Nokia Hardware & Hardware Repair | 1 | 01-07-2009 01:49 |
n95 blank screen | tornado2008 | Nokia Hardware & Hardware Repair | 11 | 10-08-2008 00:30 |
