Old 07-24-2007, 20:34   #1 (permalink)
Member: 283474
Thanks Meter: 41
Nokia 1100 powering problem
I ve Nokia 1100 that trips off few seconds after powering on, what could be d problem and d soluution please, your ressspond is URGENTLY , Thaaanks
Old 07-24-2007, 20:37   #2 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Arrow
its not clear that its powering off after 30 sec.....first replace pf.......or else uem ic faulty....replace it & write rpl...do first try flashing after erase & ui settings...post result
regards
PUNEET14884
Old 07-24-2007, 20:40   #3 (permalink)
spider-man's Avatar
Member: 135039
Thanks Meter: 1,486
Try only to restore Factory setting and u see
Old 07-24-2007, 20:49   #4 (permalink)
cellcity's Avatar
Member: 58052
Thanks Meter: 21
I Think u right just do full factory settings if still same flash phone and then do full factory settings should be ok'
enjoy
Old 07-24-2007, 22:03   #5 (permalink)
spider-man's Avatar
Member: 135039
Thanks Meter: 1,486
enjoy
Yes , i done this lot more than one time , and it work
let us see if that work for our friend de brain box
Old 07-25-2007, 20:53   #6 (permalink)
Member: 283474
Thanks Meter: 41
Thank u All i will do as u said, but is it with system or manualy.
Old 07-26-2007, 06:57   #7 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
bords, just reheat the UPP but be careful..just estimate the heat you apply...i've done this in my 3530..the UPP is glued..
Old 07-26-2007, 18:13   #8 (permalink)
spider-man's Avatar
Member: 135039
Thanks Meter: 1,486
u try with the two method and u see result
Old 07-27-2007, 20:13   #9 (permalink)
Member: 283474
Thanks Meter: 41
I ve tried both, d manual didn't work so also with system it displays LOCAL MODE FAILED. What is d next step to yake please. it communicate and flash half way.
nokia 1100 power off after 30 second rachelyna Nokia Digital Core Technology 4 ( DCT-4 ) 9 06-02-2007 16:03
nokia 1100 power problem koreja Nokia Hardware & Hardware Repair 0 06-01-2006 20:03
Nokia 1100 Power On Problem clade Nokia Hardware & Hardware Repair 4 04-04-2006 22:07
Nokia 1100 Power Switch Problem .:AnOuaR:. Nokia Hardware & Hardware Repair 5 03-31-2006 21:38
nokia 1100 imei ?????????? problem? mohd_kanodar UFS2 + UFS3-Tornadoflasher 4 02-16-2004 13:35
Page generated in 0.18673 seconds with 9 queries
