Old 05-23-2007, 09:30   #1 (permalink)
Member: 298430
Thanks Meter: 3
Nokia 1110i headset icon
Hi all
I've got a problem with a Nokia 1110i. It's displaying a headset icon and the mic & speaker not working. Can this be a software problem?
Kind regards
T
Old 05-23-2007, 09:41   #2 (permalink)
REMO's Avatar
Member: 49339
Thanks Meter: 93
this no software problem.remove charging connecter or change.
Old 05-23-2007, 09:42   #3 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Its an HW problem, Clean Board & Charging Interface!
Old 05-23-2007, 09:47   #4 (permalink)
Member: 432364
Thanks Meter: 270
Originally Posted by Techshift View Post
Hi all
Kind regards
T
Just change charging connector...
B.r.
Sunil.
Old 06-13-2007, 16:59   #5 (permalink)
Member: 145240
Hi! I'm having this problem and I've remove the charging connector and turn on the phone. But the headset icon remains there. So the problem does not seems to be the connector.
I've already flash the phone but with the same software version. I'm having problems upgrading since newer software versions uses a different flash address.
What can be the problem?
Old 06-13-2007, 17:08   #6 (permalink)
Member: 415645
Thanks Meter: 15
its simple solution. just use handfree for 20 minuts. ur problem will solve.
i have also tested 100% result
Old 06-13-2007, 18:15   #7 (permalink)
Member: 430245
Thanks Meter: 30
i have to resolved this problim so many time its just need to cleen pcb with best regards br
nokia 6275 headset icon after 2-3 mins plz help sachin_udai Nokia Hardware & Hardware Repair 5 03-30-2011 16:04
Headset icon appear on display / Headset not work solution here.. capri Nokia Hardware & Hardware Repair 39 03-16-2011 14:47
nokia Headset icon appear on display / Headset not work hazar Nokia Hardware & Hardware Repair 2 10-13-2009 08:29
nokia Headset icon appear on display / Headset not work hazar Nokia Hardware & Hardware Repair 0 10-12-2009 22:38
Alca 320 show headset icon on display dans BF, BG, TH, BHx Series 2 11-18-2004 16:04
Page generated in 0.18035 seconds with 9 queries
