Old 06-24-2008, 16:57   #1 (permalink)
Registered User
Member: 646178
Thanks Meter: 32
2630 urgent
hi nokia 2630 blue display problem ., any one plz tell solution
Old 06-24-2008, 17:36   #2 (permalink)
Member: 64908
Thanks Meter: 9
i have problem 2630 very slow n e 1 can plz tell me the slution
Old 06-25-2008, 14:08   #3 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Have you tried to test it with another display.
Old 06-25-2008, 14:10   #4 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Try to restore setting use jaf if still full flash it.
Old 06-25-2008, 14:46   #5 (permalink)
Registered User
Member: 646178
Thanks Meter: 32
2630
yes i tried with a working display
Old 07-08-2008, 18:04   #6 (permalink)
Member: 696116
Sonork: 1581278:atoybits
Thanks Meter: 5
got the same problem anybody can help
Old 08-01-2008, 08:25   #7 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 101
Originally Posted by manyosa View Post
try To Restore Setting Use Jaf If Still Full Flash It.
Try Flash It And Set Fell Seting.....but Same Problam Phone Slow
Old 08-01-2008, 08:31   #8 (permalink)
GsmGalant's Avatar
Member: 87568
Thanks Meter: 101
If is software problem, try to read full Pm from another phone and write it then fllash and full ul setings.
Old 12-03-2008, 20:08   #9 (permalink)
psilva's Avatar
Member: 468642
Thanks Meter: 36
hi
i do all of these things but not working i need solution please anyone give me the solution please .
best regards
crazytel
Old 12-03-2008, 20:20   #10 (permalink)
Member: 675717
Thanks Meter: 125
You can change crystal clock if not ok you can change UPP i know this is very hard work.Thanks
Old 12-03-2008, 20:44   #11 (permalink)
Member: 270990
Thanks Meter: 3
if display shows blue light only,i can surely say only light circuit is working and single or more wires are damaged from LCD flex or from main board conector
Old 12-03-2008, 20:48   #12 (permalink)
psilva's Avatar
Member: 468642
Thanks Meter: 36
thank's friends for help
regards
crazytel
Old 01-08-2009, 17:55   #13 (permalink)
PANTECH N B R's Avatar
Member: 927663
Thanks Meter: 40
2630 blue display solution
1.display change checking
2.vio pin - 3
3.vflash pin - 22
4.connector replace
5.upp reboll
2630 flash files want urgent .RAM Nokia Base Band 5 ( BB-5 ) 1 10-08-2009 07:07
2630 urgent help vaghubha_sodha Nokia Hardware & Hardware Repair 4 07-14-2009 15:56
Urgently needed nokia 2630 cable pinout.. harim_1981 MT-BOX 14 12-05-2007 17:23
Page generated in 0.21689 seconds with 9 queries
