10-08-2007, 12:17 | #1 (permalink) |
Insane Poster Join Date: May 2007
Member: 508595 Status: Offline Thanks Meter: 14 | NOKIA 3230 when Insert the battery LCD display white light but phone is working fine When I insert the battery in NOKIA 3230 (RM-51) the lcd screen comes white and when I switch on the phone is working fine. When Trying to switch off this phone the switch button is not working. tell me how to solve the problem I have use UI settings and clean the PCB, but no solution. please help me. with regards Tarik |
10-08-2007, 14:54 | #3 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | Yes I agree with Mr. capri.but shortage could be in another area. check all the unit with a lot of care about water damage. and post results. |
The Following User Says Thank You to astana2007 For This Useful Post: |
10-11-2007, 07:03 | #4 (permalink) |
Member: 508595 Status: Offline Thanks Meter: 14 | Thanks sir, I have clean the PCB and now there is no short circuit. but now when I insert the battery the phone is automatically switched on and the power switch is not working, phone also woriking properly after automatic switch on. I am sure that there is no short circuit in PCB. Tell me whats worng with this, regards tarik. |
The Following User Says Thank You to tarikalikhan For This Useful Post: |
10-11-2007, 07:44 | #5 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | There is still shortage but very minor. now check the edges of all the ic,s. some water is still there and the golden color of ic,s might be in black color,due to of water. especially check with the help of glass. due to of that water some points r short and creating problem. check and post results. |
10-11-2007, 13:02 | #6 (permalink) |
Member: 508595 Status: Offline Thanks Meter: 14 | Sir, Will You Please Upload A Picture Of The Same, And In Which Area. I Did Not Find, Thanks, Regards, Tarik |
10-11-2007, 14:08 | #7 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 366974 Status: Offline Thanks Meter: 31 | try to clean UI Board connector. That at left side from main board. i try this many times and works 100%. if you sure that connector is clean and ok. thats UPP problem. i was have a problem like that and change UPP. Phone works 100% |
The Following User Says Thank You to neokia For This Useful Post: |
10-21-2008, 10:17 | #9 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: pahang Age: 37
Member: 792839 Status: Offline Thanks Meter: 1,104 | Quote:
The Following User Says Thank You to alvine281 For This Useful Post: |
10-21-2008, 11:05 | #10 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | yes I also agree with capri there is a minor shortage still , so clean the pcb deeply or replace ui board & check |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
11-29-2008, 18:15 | #11 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 446881 Status: Offline Thanks Meter: 707 | Brother's your problem Is 100% Solved Here. Nokia 3230 Lcd Display Back Lights Problem Mobile Repairing Picture Help |
The Following User Says Thank You to saqib_islam For This Useful Post: |
Failed! Aborting! but phone is working! | jaleelkuttikkar | J.A.F. By Jafsupport.com | 12 | 06-10-2009 04:18 |
Sl data fffffffffff but set is working fine | nazar2008 | Universalbox | 5 | 03-26-2009 15:53 |
N72 White Light But Set Is Making Ring.. | alamgarh | Nokia Base Band 5 ( BB-5 ) | 2 | 06-07-2008 11:57 |
v980 No Lcd..But Phone is working.. | LoveLess | Smart-Clip | 4 | 10-16-2007 07:54 |
6600 phone is working but white light | vinay_sharma | Nokia Hardware & Hardware Repair | 3 | 11-08-2006 22:41 |
