Old 10-07-2006, 13:30   #1 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 658
Nokia 1110 Display Problem
Dear sir i have nokia 1110 i flashed it with JAF and now its working and when swiched on its on and show only nokia on the lcd after that screen is total blank and set is working properly making call receiving call. i changed the lcd but problem is still there please help me what to do.
The Following 3 Users Say Thank You to zubairok For This Useful Post:
Old 06-01-2007, 15:46   #2 (permalink)
Member: 363878
Thanks Meter: 61
solve this problem
event some case. you can got idea
nokia 1110 some one broken lcd. i chang new one is lcd 1110i but is show only nokia and boot on ok. but display is strang can't read. call and received call ok.
first time i check all line socket and second i think software problem
but it all wrong way.
i try to flash ufs with 1110i/1112 version but phone got "contact service" ... i have to use flash with nokia 1110 same real type of phone.
it ok. and i use with lcd nokia 1600 to test it agian this play all ok.
This case i think this display upon version. and display must compatible your phone .. (i ever use lcd nokia 1110i with 1110 phone it ok but not for all case)
The Following 3 Users Say Thank You to lsurasak For This Useful Post:
Old 07-21-2007, 11:53   #3 (permalink)
Member: 350948
Thanks Meter: 32
N 1110 Rh93 display problem (after flash)
I have got solution for this problem.I just flash with latest version RH93Ver 6.41.Using JAf & problem solved .. Try & post here...Also threr is no need to change display.If not damaged....
The Following 4 Users Say Thank You to shritelmob For This Useful Post:
Old 07-21-2007, 15:31   #4 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 301
Lightbulb
Or Flash wiz nokia 1600 Flash File (RH-64-dp_v_26_01_MCUSW6_00)
+ change lcd, put 1600 lcd
ur phone is nw nokia 1600!!!!!!!!!!!!!!!!!!
The Following 3 Users Say Thank You to khem For This Useful Post:
Old 07-21-2007, 15:50   #5 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
atach to jaf and see info and see display type there.and flash with latest version.
The Following User Says Thank You to baldev For This Useful Post:
Old 12-02-2007, 08:51   #6 (permalink)
Member: 303914
Thanks Meter: 2
hi sir can you pls, give me circuit lay out
thanks
The Following User Says Thank You to aljhads For This Useful Post:
Old 12-02-2007, 08:54   #7 (permalink)
Member: 303914
Thanks Meter: 2
can you give me lcd circuit lay out anybody pls
Old 01-17-2008, 08:33   #8 (permalink)
Member: 289014
Nokia 1112 display prblem event some case. you can got idea
This case i think this display upon version. and display must compatible your phone .. (i ever use lcd nokia 1110i with 1110 phone it ok but not for all case) not okkkkkkkkkkkkkk
The Following User Says Thank You to waqar1985 For This Useful Post:
Old 03-26-2008, 12:42   #9 (permalink)
Member: 290127
hi bro i have sony ericssion w610i problem is cannot on pls any body tel me the solution
The Following User Says Thank You to srjhtech For This Useful Post:
Old 03-26-2008, 13:08   #10 (permalink)
riadhset's Avatar
Member: 39239
Thanks Meter: 97
http://forum.gsmhosting.com/vbb/atta...5&d=1189311449
The Following User Says Thank You to riadhset For This Useful Post:
Old 04-01-2008, 13:28   #11 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
Bro Try This Solution & I Think Its 80% Work
The Following 7 Users Say Thank You to sujan1050 For This Useful Post:
Old 07-07-2008, 15:28   #12 (permalink)
Member: 709604
Thanks Meter: 173
i have one 1110 get info it shown unknown lcd ic pls give me the solutoin for this i am facing this problem in ten mobile phones
Old 06-19-2012, 15:30   #13 (permalink)
Member: 1103371
Thanks Meter: 19
Cool nokia 1600 lcd jumper
Welcome to Cell Dial
File Type: jpg nokia 1110,1110i,1600,2310 LCD JUMPER.jpg (104.0 KB, 109 views)
Old 06-19-2012, 16:14   #14 (permalink)
Member: 1774069
[IMG]http://www.****************.com[/IMG]Thanks for sharing.
nokia 1110 displaying nokia after on de brain box Nokia Hardware & Hardware Repair 13 08-26-2010 07:38
nokia 1110 display fast2pk Nokia Hardware & Hardware Repair 13 09-09-2009 12:33
nokia 1110 display problem nitinkansara Nokia Hardware & Hardware Repair 5 10-31-2008 11:37
nokia 1110 display problem vinkle Nokia Hardware & Hardware Repair 2 09-12-2008 16:55
Nokia 1110 display service info in standby pitone02 Nokia Digital Core Technology 4 ( DCT-4 ) 3 06-23-2008 18:44
Page generated in 0.26399 seconds with 10 queries
