Old 04-13-2007, 05:07   #1 (permalink)
Member: 66045
Thanks Meter: 4
Nokia 6681 display breaking into multi color
Hi all,
i have a n 6681 whose display got damaged due to fall. Now when i put a new display, only on start up i get proper nokia but soon after the "Nokia" gets inverted and is displayed on the top of the display and then on normal boot up the color is broken into many parts.
please help
thanks
regards
Akash
Old 04-13-2007, 06:01   #2 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
change with new display if not work then slightly heat display ic
Old 08-21-2007, 08:41   #3 (permalink)
Member: 215651
Thanks Meter: 7
i have a n 6681 whose display got damaged due to fall. Now when i put a new display, only on start up i get proper nokia but soon after the "Nokia" gets inverted and is displayed on the top of the display and then on normal boot up the color is broken into many parts i am 2or 3 display changing but no result pls any body help urgent................
Old 08-21-2007, 10:47   #4 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
br change dispaly driver ics 100% working
..::Mr Fone::..
Old 08-21-2007, 15:29   #5 (permalink)
Crazy Poster
Member: 165216
dont reheat or change anything you could kill those usefull displays, instead look for a compatible display, for example if you use a 6680, 7610 or a 6600 display in a 6682 you will get same result after logo screen, but everything goes ok with a 6630 display, test some displays or check compatibility betewn those in hardware stores.
Old 08-21-2007, 19:43   #6 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Replace the LCD IC @ right side.
Check also supply voltage VIO 1.8v and VAUX 2.8v
nokia 2600 display connector break ashish mobile Nokia Digital Core Technology 4 ( DCT-4 ) 10 01-05-2011 19:01
my treo 755 wont work displays multi color screen BenSpartan PalmOS /HP and others 0 06-22-2009 20:04
Berg Color-Tone Standard Multi-Color Toning Kit for BlackWhite Prints or Transparenci IPMART ipmart WebShop 0 11-27-2008 11:10
Nokia 6681 display way's dev452005 Nokia Hardware & Hardware Repair 0 08-22-2008 07:48
6681 Display Problem-but In It 6680 Display Works Fine zonetrichur Nokia Hardware & Hardware Repair 0 03-11-2007 14:04
Page generated in 0.17075 seconds with 9 queries
