Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 11-27-2009, 02:42   #1 (permalink)
palav's Avatar
Member: 1098397
nokia 7610 phone start-up failed help me pls
1st network problem
changes pfo notwork
but flash phone
per phone start-up failed.contact the retailer help me pls
Old 11-27-2009, 02:57   #2 (permalink)
Member: 706886
jaf ,do >>>file syetem format,until,jaf format ok.
if u use ufs,press format user are,>>>>>until format user area ok.
br
Old 11-27-2009, 04:51   #3 (permalink)
Binoy.c's Avatar
Member: 523496
Sonork: ammachis
do number formatting then try factory resetting in jaf or ufsthen formatit
Old 11-27-2009, 04:58   #4 (permalink)
vaghubha_sodha's Avatar
Member: 823633
Sonork: 9898260467
bro try hand formet
power key .call key.*key. 3key
Old 11-27-2009, 04:59   #5 (permalink)
farihabest's Avatar
Member: 617692
flash and unlock with mxkey
Old 11-27-2009, 05:59   #6 (permalink)
Member: 655438
If u are using the UFS.
1. Erase the handset useing erase flash option.
2. Flash the handset with latest version file
3. Write a good pm file in it.
4. Format user area.
5. At last in U.I. options do last 3 (reset user lock, init simlocks and reboot in Normal Mode).
Old 11-27-2009, 06:06   #7 (permalink)
gul_hassan528's Avatar
Member: 420821
Sonork: 100.1603493
only format user area with ufs
Old 11-27-2009, 06:43   #8 (permalink)
TrustUnlocking™'s Avatar
Member: 753117
Sonork: 100.1611207
bro change data ic and and hand flash set 99%ok
Old 11-27-2009, 06:53   #9 (permalink)
farihabest's Avatar
Member: 617692
Originally Posted by palav View Post
1st network problem
changes pfo notwork
but flash phone
Brother first post your info log
then we can help you
Old 11-27-2009, 06:58   #10 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
1st network problem
changes pfo notwork
but flash phone
contact rertailer in WD-2 is only due to user area
just format it problem will be solved
it is pertinenet to mentioned here that if contact retailer is due to hardware than never will solve through software format/flash
Old 11-27-2009, 10:08   #11 (permalink)
palav's Avatar
Member: 1098397
i use jaf box
info
Powering the phone...
Reading...
MCU SW version: V 7.0642.0
18-10-06
RH-51
(c)NMP
HW version: 6003
PCI version:
UEM version: 144
UPP version: 4225
Production serial number: DDE722549
Product code: 0514521
Module code: 0202215
Basic production code: 0511637
Flash code:
Order number: 1234567
Long production SN:
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 357087008976173
IMEI spare to net: 3A 75 80 07 80 79 16 07
IMEI SV to net: 33 75 80 07 80 79 16 37 F3
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 2323106504
Phone type: RH-51, Software version: 7.0642.0, Language Pack: 26
User code: 12345
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0514521
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Scanning for ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.33
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Bahasa Mal.,Bahasa Ind. (Apac-3)
Done!
CHK
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
Old 11-27-2009, 16:46   #12 (permalink)
palav's Avatar
Member: 1098397
help me pls............
Old 12-01-2009, 04:54   #13 (permalink)
farihabest's Avatar
Member: 617692
hmm....The problem will be solved only with formatting. Brother just format with UFS or use the formula to format the phone.
step 1
Turn off the phone
Press and hold the three buttons *(star),3(three) and yes button(green button) and then Turn on the phone. Format will start.
If format does not start with formula then apply the two formulas first:
step 2
*#7780#
*#7370#
then start from step 1
Old 12-10-2009, 09:09   #14 (permalink)
Member: 706886
or try this with jaf :
-conect phone to jaf box
-phone mode,set to test mode
-do file system format,until>>>>jaf format ok.
br.
Old 12-11-2009, 06:51   #15 (permalink)
Member: 538525
only do flash & formate user area not ui seting 100% working post result
nokia 3230 phone start-up failed help me palav Nokia Hardware & Hardware-Repair Area 10 08-28-2011 10:34
Nokia N96 phone start-up failed. help me rafiqcell Nokia Base Band 5 ( BB-5 ) 6 01-16-2010 05:38
N96 After unlock phone start up fail help me chamin Nokia Base Band 5 ( BB-5 ) 9 06-26-2009 12:30
Nokia 7610 Phone start up failed mobilecitycbk Nokia Hardware & Hardware-Repair Area 8 04-27-2008 12:43
Page generated in 0.86348 seconds with 11 queries
