11-22-2004, 19:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | Nokia 7650 restarting I also have nokia 7650 which is restarting. I have flashed phone but i can not reach local/test mode coz phone is still restarting. So i can not make USER AREA FORMAT. Anybody can help me? regaRds.. Yoda. |
11-23-2004, 14:38 | #2 (permalink) |
Member: 40423 Status: Offline Thanks Meter: 5 | Reflowed UPP + UEM, but no succes. i can flash phone but after flash i am unable put phone to local mode. Phone 3x restarts (logo NOKIA for 1 sec, then rastart) Please WD2 phones experts.. anyone help? |
11-24-2004, 14:41 | #4 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: GermanY
Member: 38922 Status: Offline Thanks Meter: 35 | Quote:
Use Prodigy to boot in Local Mode, with press on [L] on the right side Menü. Clean your cablecontacts + resold flash... GreetZ | |
11-24-2004, 14:59 | #5 (permalink) |
Member: 40423 Status: Offline Thanks Meter: 5 | Lol. reflowed everything. UPP, UEM, FLASH, SRAM, Bluetooth, Hagar etc.. Problem still here. What for use Prodigy box? I am using Matrix, Griff, Twister. On all devices flashing succesfull, also tried to erase whole flash and upload FW from older to newest. I can not switch phone to LOCAL that is my problem. So do not post that i have to boot it in local. Phone is unable to stay on longer than 2 sec connected to any device. But thanks for reply. And which method i have to use? |
11-24-2004, 15:17 | #6 (permalink) |
Freak Poster Join Date: Nov 2004 Location: philippines
Member: 93544 Status: Offline Thanks Meter: 1 | hello, try to erase both mcu and ppm by using pmmerase. after you flash the phone it become dead. after that then you flash it with normal flash for 7650. the phone will now turn to local mode. format it then write pm and unlock. hope this will help. i tried this my friend. ber747 |
11-24-2004, 16:55 | #7 (permalink) |
Member: 40423 Status: Offline Thanks Meter: 5 | I have some erasing flash files (FIA/BIN files) but i am not sure that i can use them for 7650 (NHL2-NA) i have these > nhl2_eerase.bin nhl2_eeraseFULL.bin i have tried to upload them using Twister and Matrix but no succes. Matrix writes "Wrong Flash File" twister writes > 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x00FFFFFF,00898876,Int 28F128W18-T Fl1: 0x02000000-0x023FFFFF,000122D1,Amd 29BDS323D Algorithm: w2_int_b.fia Algorithm Ok, MSID: 84E584F14EEAAD4C75AC6612E0 Decoded MSID: 3E4EBAF7-00CB5927-A8000000 Encoded FAID: 7A2591E5-18242EA9-C89C6085 Area: 0x00EDA000-0x00FFFFFF Erased, Time: 00:14 Erasing: 0x02000000-0x02FFFFFF ... Erasing Error: 10, at: 0x02000000-0x0201FFFF, 940207 Process Failed, Repowering Mobile Please any more ideas? or can someone shar good erase file for 7650? |
11-26-2004, 17:23 | #9 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia, Yaroslavl Age: 43
Member: 46415 Status: Offline Thanks Meter: 16 | 2 eivoig: quite right, man! :-) 2 Yoda_Brno: you have to check your cable, or put the phone manually in local: connect BSI to GND - phone must be in local. then use griffin and flash the phone (using manual mode) with fullerase.fia (for example, i used erase.fia for 3650). write fullerase.fia as ppm without mcu, then phone will be totally dead. Then manually flash it with usual mcu+ppm, then write pm values, unlock. works 100% if it isn't hardware problem. good luck, man. |
11-26-2004, 17:32 | #10 (permalink) |
Member: 40423 Status: Offline Thanks Meter: 5 | 2 Masta.G i have already tried. where i have to search HW fault? i have reflowed everything reflowable in the phone. Now i have to change some IC but i dont know which one? |
Nokia 7650 boot failed, stuck only in NOKIA logo | ianskiee | Nokia Hardware & Hardware Repair | 0 | 03-07-2006 10:22 |
7650 Restart Problem | sawy2002 | Nokia Hardware & Hardware Repair | 7 | 01-08-2004 11:46 |
nokia 8310 y nokia 7650 | zizou23 | Phone Unlocking Codes & Maps | 0 | 02-28-2003 18:53 |
Nokia 7650 | fofodaman | Main Sales Section | 2 | 05-12-2002 11:05 |
Buy Nokia 7650....is it actually available anywhere? | Nokia man | WD2 & APE (Symbian Phones) | 1 | 04-04-2002 21:07 |
