Old 05-13-2013, 17:58   #1 (permalink)
shehryar mardan's Avatar
Member: 1033862
Sonork: 100.1652017
Thanks Meter: 538
Nokia c3-00 auto off in ring tune
I have nokia c3-00
when i select ringtunes or volume
its being turn off it becomes turn off in ringtunes
i flashed it with latest version but still same problem
FACTORY RESET FULL BUT SAME
any idea plz
thnx
Old 05-13-2013, 18:05   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
seems software issue (cnt problem) try to flash with another version .
Old 05-13-2013, 18:07   #3 (permalink)
Member: 1033862
Sonork: 100.1652017
Thanks Meter: 538
Already tried with another file
Old 05-13-2013, 18:47   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
ok , check mobile current consumption . reply .
Old 05-15-2013, 14:12   #5 (permalink)
Member: 1033862
Sonork: 100.1652017
Thanks Meter: 538
Consumption is perfact working
Old 05-15-2013, 14:19   #6 (permalink)
mojee's Avatar
Member: 629391
Thanks Meter: 396
ringer problem change speaker and post result.
Old 05-16-2013, 09:38   #7 (permalink)
Member: 1540810
Sonork: 100.1627394
Thanks Meter: 161
Remove vibrator 100% solution press thanks if useful for you
The Following User Says Thank You to Engiess For This Useful Post:
Old 05-20-2013, 08:27   #8 (permalink)
Member: 967368
Sonork: anil19
Thanks Meter: 15
I have same problem i remove vibrator set working now
you try to it.........................
Old 05-20-2013, 11:46   #9 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
change ringer and post result...... or try to check without ringer.....
Old 05-21-2013, 08:16   #10 (permalink)
Member: 1557171
Remove vibrator 100000000000% solution press thanks if useful for you ............................anwargreat
Old 05-26-2013, 17:07   #11 (permalink)
Member: 1033862
Sonork: 100.1652017
Thanks Meter: 538
dear moderator plz delete this tread i got my solution
Old 05-26-2013, 17:20   #12 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
Would you like to share your solution so others can take advantage and should not search
Old 05-27-2013, 08:20   #13 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,410
change volume keys............................
Old 09-17-2013, 08:45   #14 (permalink)
Member: 1033862
Sonork: 100.1652017
Thanks Meter: 538
problem solved with removing vibrator
Old 04-24-2014, 12:13   #15 (permalink)
Crazy Poster
Member: 894785
Thanks Meter: 8
Page generated in 0.18181 seconds with 8 queries
