![]() | #1 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Apr 2008 Location: j&k india
Member: 744259 Status: Offline Thanks Meter: 11 | nokia n70 problem RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAPx PBID : 0DA0011797E04951F3C232ED59963AAC83AB6B76 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK Rebooting Mobile product selection missmatch also smps ic output voltage is 1.8v instead of 1.4v please what will be the problem |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | Quote:
![]() | #3 (permalink) |
Member: 744259 Status: Offline Thanks Meter: 11 | n70 problem but flashing is not possible during error .also i replace smps ic many times every time output voltage of smps ic [v.core] is 0.65 or 1.8v instead of 1.4v by the result set shows product selection mismatch when i check it by hwk original , set shows as under 1ST BOOT : C0,07 [Rm-84] RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAPx PBID : 0DA0011797E04951F3C232ED59963AAC83AB6B76 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK Rebooting Mobile are these smps ic are defective or set is defective please reply me that will be your kindness |
![]() | #5 (permalink) |
Member: 744259 Status: Offline Thanks Meter: 11 | n70 problem after that i replace again smps ic now v.core is 2v and vddr.ape is 1.8v & i check it again now set shows 1ST BOOT : C0,0C [Rm-84] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 2306B38FDA3D21AF7C924B5CA38D50F8AA1A0DA4 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAPx PBID : 0DA0011797E04951F3C232ED59963AAC83AB6B76 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0 00000000: 04 00 00 00 00 B1 72 ......r ERR: APE 2ND Boot FLB_MSG_C2: APE 2ND CONF No Info Rebooting Mobile Init Local Mode Ok, Time: 00:00 Init Test Mode Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:00 sir what is the problem now |
![]() | #10 (permalink) |
Member: 744259 Status: Offline Thanks Meter: 11 | i have many times change the n4200 smps ic it do"t gives v core i.4 but it gives more than 1.4v i.e. like 2v or 2.5v .can this over voltage causes the above error , if yes then how can i change this ic to give it acurate v core 1.4v |
![]() | #12 (permalink) |
Member: 744259 Status: Offline Thanks Meter: 11 | my iphone apple A1203 shows iphone disabbled connect to itones when ever we switch on the set , incomming and out going calls are ok , only set not shows menu on screen, i have hard restore it but the problem is same , any body help me sir |
Nokia N70 problem | gigione01 | Nokia Hardware & Hardware Repair | 10 | 05-15-2012 14:11 |
Nokia N70 Problems | klorel | Nokia Base Band 5 ( BB-5 ) | 4 | 10-20-2010 08:27 |
Nokia N70 problem | fareedreg | Nokia Hardware & Hardware Repair | 9 | 12-09-2008 11:48 |
Nokia N70 problem unlock | said4 | HWK | 0 | 02-01-2008 07:06 |
