08-08-2009, 18:14 | #9 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | This is my solution. I already tested/proven three times already. Remove the small square black ic at the back of the keypad membrane/assembly. Then try if the keypad still hangs after several secs/mins w/o the ic. Phone's keypads works normally even w/o this ic. Then post the result. Br, |
The Following 12 Users Say Thank You to Dj King For This Useful Post: |
08-08-2009, 23:55 | #10 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: SYR
Member: 189831 Status: Offline Thanks Meter: 100 | Quote:
do you main removing black IC forever or replace it ? Now mobile is ok after changing keypad, but i will try your solution any way | |
The Following 3 Users Say Thank You to SMK For This Useful Post: |
08-10-2009, 02:24 | #12 (permalink) |
Member: 6428 Status: Offline Thanks Meter: 43 | Thats great! So, we don't have to buy a brand new keypad assembly just to fix the phone. All you have to do is just remove the black ic and thats it. The real and simple solution. Now, the problem in n79 keypad issue is now resolved. Br, Last edited by Dj King; 08-10-2009 at 02:30. |
The Following 9 Users Say Thank You to Dj King For This Useful Post: |
08-21-2009, 09:02 | #13 (permalink) |
Major Poster Join Date: Jun 2007 Location: Pakistan Age: 35
Member: 530632 Status: Offline Thanks Meter: 18 | hey guys....its abdullah from pk im in desperate help right here....i m having the same prob with my n79 and its been like 2 weeks now the repairman i gave the cell toO has put out the indicated chip and now the keypad dosnt work at all can u guys please tell me what exactly does this chip do? can u please guide me that if i change the keypad assembly will it work?? cause i m totally clueless right now the solution should have worked but it didn't |
The Following 4 Users Say Thank You to max414 For This Useful Post: |
08-21-2009, 16:36 | #14 (permalink) |
Member: 530632 Status: Offline Thanks Meter: 18 | UPDATE i got the ic removed and installed back in again and now THE KEYPAD DOES NOT WORK AT ALL!!! help me out guyz |
The Following 3 Users Say Thank You to max414 For This Useful Post: |
08-21-2009, 16:37 | #15 (permalink) |
» NOkia White Screen Hang Solutions in one exe | bgreat | Nokia Hardware & Hardware Repair | 11 | 11-10-2010 06:02 |
nokia n79 keypad notwork | akram855 | Hardware Repair Item Wanted | 4 | 11-25-2009 09:49 |
NOkia White Screen Hang Solutions in one exe. by Mehmood Riaz | izhanji | Nokia Hardware & Hardware Repair | 75 | 11-05-2009 19:45 |
nokia 6060 keypad hang. | bashir_icon | Nokia Hardware & Hardware Repair | 1 | 01-25-2009 09:05 |
Philips S200 keypad hang solution | reaz.com | Philips | 7 | 08-04-2007 05:55 |
