Old 07-14-2009, 07:35   #1 (permalink)
basilbaby's Avatar
Member: 263709
Thanks Meter: 327
Nokia N79 Keypad Hang Solution..
The Following 86 Users Say Thank You to basilbaby For This Useful Post:
Old 07-14-2009, 07:37   #2 (permalink)
Member: 440768
Thanks Meter: 7
good work keep it up bro...........
The Following 3 Users Say Thank You to mehtabdecentmob For This Useful Post:
Old 07-14-2009, 10:00   #3 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
will test and post results ,
anyway thanks for good share
The Following 2 Users Say Thank You to shahjee For This Useful Post:
Old 08-04-2009, 13:34   #4 (permalink)
SMK
Member: 189831
Thanks Meter: 100
From any board can get this IC N2850 ?
The Following 3 Users Say Thank You to SMK For This Useful Post:
Old 08-06-2009, 16:55   #5 (permalink)
SMK
Member: 189831
Thanks Meter: 100
Please is there an other Solution
all keypad hang after 2-3 second
Old 08-06-2009, 17:23   #6 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
bro try to flash for hang,,,,,
The Following 3 Users Say Thank You to gsmshare For This Useful Post:
Old 08-08-2009, 06:39   #7 (permalink)
basilbaby's Avatar
Member: 263709
Thanks Meter: 327
Try the above solution.. Good luck
The Following 3 Users Say Thank You to basilbaby For This Useful Post:
Old 08-08-2009, 16:59   #8 (permalink)
SMK
Member: 189831
Thanks Meter: 100
I did it & flash it but still the same
Old 08-08-2009, 18:14   #9 (permalink)
Member: 6428
Thanks Meter: 43
This is my solution. I already tested/proven three times already.
Remove the small square black ic at the back of the keypad membrane/assembly. Then try if the keypad still hangs after several secs/mins w/o the ic. Phone's keypads works normally even w/o this ic. Then post the result.
Br,
The Following 12 Users Say Thank You to Dj King For This Useful Post:
Old 08-08-2009, 23:55   #10 (permalink)
SMK
Member: 189831
Thanks Meter: 100
Br,
I will try
do you main removing black IC forever or replace it ?
Now mobile is ok after changing keypad, but i will try your solution any way
Old 08-09-2009, 20:57   #11 (permalink)
SMK
Member: 189831
Thanks Meter: 100
N79 Keypad Hang Solved
After removing the BLACK IC keypad now work fine
The Following 6 Users Say Thank You to SMK For This Useful Post:
Old 08-10-2009, 02:24   #12 (permalink)
Member: 6428
Thanks Meter: 43
Thats great! So, we don't have to buy a brand new keypad assembly just to fix the phone. All you have to do is just remove the black ic and thats it. The real and simple solution. Now, the problem in n79 keypad issue is now resolved.
Br,
The Following 9 Users Say Thank You to Dj King For This Useful Post:
Old 08-21-2009, 09:02   #13 (permalink)
Member: 530632
Thanks Meter: 18
hey guys....its abdullah from pk
im in desperate help right here....i m having the same prob with my n79 and its been like 2 weeks now
the repairman i gave the cell toO has put out the indicated chip and now the keypad dosnt work at all
can u guys please tell me what exactly does this chip do?
can u please guide me that if i change the keypad assembly will it work??
cause i m totally clueless right now
the solution should have worked but it didn't
The Following 4 Users Say Thank You to max414 For This Useful Post:
Old 08-21-2009, 16:36   #14 (permalink)
Member: 530632
Thanks Meter: 18
UPDATE
i got the ic removed and installed back in again
and now
THE KEYPAD DOES NOT WORK AT ALL!!!
help me out guyz
The Following 3 Users Say Thank You to max414 For This Useful Post:
Old 08-21-2009, 16:37   #15 (permalink)
Member: 530632
Thanks Meter: 18
UPDATE
and now
help me out guyz
» NOkia White Screen Hang Solutions in one exe bgreat Nokia Hardware & Hardware Repair 11 11-10-2010 06:02
nokia n79 keypad notwork akram855 Hardware Repair Item Wanted 4 11-25-2009 09:49
NOkia White Screen Hang Solutions in one exe. by Mehmood Riaz izhanji Nokia Hardware & Hardware Repair 75 11-05-2009 19:45
nokia 6060 keypad hang. bashir_icon Nokia Hardware & Hardware Repair 1 01-25-2009 09:05
Philips S200 keypad hang solution reaz.com Philips 7 08-04-2007 05:55
Page generated in 0.30755 seconds with 10 queries
