Old 03-20-2002, 03:18   #1 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
One Question On Pf....
hI firends i need your opinion is PF08103B the same of PF08103A?
Tanks
Old 03-20-2002, 05:34   #2 (permalink)
D-Brain's Avatar
Member: 7301
Hi Pandemonio!
I think they are full compatible. Sometimes I've used a PF08112 instead of a PF08109 in a NOKIA 3310, so 01803a/b should be very simlar!
If you want more infos on Hitachi PA look at this doc:
http://global.hitachi.com/Sp/TJ-e/19...r99/r2_106.pdf
ByeZ
D-Brain
P.S. Da dov'e' che scrivi??
Old 03-20-2002, 15:10   #3 (permalink)
Member: 7767
Thanks Meter: 3
100% compatible
Old 03-20-2002, 17:19   #4 (permalink)
Member: 3381
Thanks Meter: 1,171
I think that there is a difference because if you look the color under pF is different is possible one work 3.5v and another 5v?
Chuk yohave personal tested changing pf on 8210 whit C25?
Old 03-21-2002, 02:52   #5 (permalink)
Member: 5850
They are not compatible, because of different power suplly
If you will try to solder PF08103B to Er1018, it will work very bad.
Old 03-22-2002, 02:14   #6 (permalink)
Member: 3381
Thanks Meter: 1,171
Yes i have desolder from C25 because i don't have disponible in laboratory but the phone don't recognize the network.
Now i am lokking another price list where give PF08103B compatible whit PF08105A which phone use this?
Old 03-23-2002, 17:50   #7 (permalink)
Member: 7767
Thanks Meter: 3
I personal test it on Panasonic gd 30, Siemens C25 PF...103A=103B.
Old 03-24-2002, 09:06   #8 (permalink)
genocite's Avatar
Member: 5379
from the number the pf maybe the same, but i think if we replace a lower working voltage pf (3.5v) in a higher voltage phone (5v), the pa will work but not in a long time and will be shorted soon.
higher working voltage pf (5v) in a lower voltage phone (3.5v) will caused the pf to work very weak
One Question About Cruiser,pls Gubby_J Cruiser Suite 2 03-29-2010 12:46
activation string require on pf acer(setup ver 3.3) may_power Programs Keys & H/W finger prints 10 06-18-2009 09:10
one question about using ubl easytp directly on phone? monsterpassword BB5BOX 0 09-29-2007 04:13
Only one question to Lead to make decision on upgrading to Cruiser... FractalizeR Cruiser Suite 36 12-17-2004 11:00
One Question on the Moderators! Meam Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 07-19-2001 17:30
Page generated in 0.21048 seconds with 9 queries
