Old 06-14-2006, 16:15   #1 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
pls help me , NOKIA PROFESIONALS ....!!
When i got nokia 6230 that can be flashed BOT BO POWER after thatm
how can we decide which ic responsable for this ....
UPP, UEM, Flash, SDRAM ...?
PLS HELP!!!
i hate try this , or this ..., i want to do some test and find out the problem ...
Old 06-14-2006, 16:52   #2 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ Byte,
pls. clear what you want to say about your problem ?
you wrote this.
"When i got nokia 6230 that can be flashed BOT BO POWER after thatm"
you mean, 6230 that can be flashed BUT NO POWER on after that ?
wbr
Old 06-14-2006, 16:55   #3 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
Smile
first full flash the phone
erase then flash..... and write good pm
and reply
Old 06-14-2006, 18:18   #4 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
Originally Posted by baraka42
@ Byte,
wbr
excatly .....
pls help
Old 06-15-2006, 05:47   #5 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ Byte,
why don't you search befor ask ?
http://forum.gsmhosting.com/vbb/show...ght=6230+power
wbr
Old 06-15-2006, 06:28   #6 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
@baraka42
first thread : phone can power on on BOX, : NO TESTING PROCEDURE TO IDETIFY THE PROBLEM
secound thread : NO TESTING PROCEDURE TO IDETINFY THE FAULTY IC
Third thread : ALSO NO TESTIG PROCEDURE TO IDETIFY THE FAULTY IC
as u know in my post, i'm asking for "some test and find out the problem ..."
BYTE
Old 06-15-2006, 09:26   #7 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
here is the log from jaf:
Booting phone...
MCU ID: 0x1052
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Loader version: 04.34.00 -> Revision: 0007
Boot size is 0x2338
Error booting phone...
MCU: C:\Program Files\Nokia\Phoenix\products\RH-12\rh12_28_11005.500
Booting phone...
MCU ID: 0x1052
Boot size is 0x2338
Boot is ready...
FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0x22F800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
Loader size is 0x8290; Loader chk: 5
Loader is ready...
P-key nokia module version 01.00
MSID: 847CF035E22DE2D1110CBC42FC
MSID decoded: B03FBAE900DF3DA9A9000000
FAID: 90EFEB50E37B5BB2453E881F
Operation took 0 minutes 16 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 007FFFFF...
Erasing area: 00800000 - 0093FFFF...
Erasing area: 00B60000 - 00FEFFFF...
Operation took 2 minutes 8 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 51 seconds...
Restarting MCU...
NAND Format FAILED!!!
CNT: C:\Program Files\Nokia\Phoenix\products\RH-12\rh12_28_11005.50.ucp_a
Booting phone...
MCU ID: 0x1052
Boot size is 0x2338
Boot is ready...
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Loader is ready...
MSID: 844D6AA831C682456D52A92477
MSID decoded: 3E4EBAE900DF3DA9A9000000
FAID: 985E28A6591C0D556B6278B0
Operation took 0 minutes 17 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 00940000 - 00B3FFFF...
Operation took 0 minutes 18 seconds...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
Operation took 0 minutes 1 seconds...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\products\RH-12\rh12_28_11005.50a
Booting phone...
MCU ID: 0x1052
Boot size is 0x2338
Boot is ready...
Loader is ready...
Erasing PPM...
Operation took 0 minutes 19 seconds...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Flashing Done!
Operation took 5 minutes 46 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
i try without cnt file , the same problem .!!!!
how to do a TEST to identify the faulty IC ?
Old 06-15-2006, 13:39   #8 (permalink)
Member: 115570
Thanks Meter: 13
you can not test, where the problem is located.
it can be a short-circuit
it can be a faulty RAM
it can be a dead PM area
it can be a faulty power supply IC
it can be a faulty quartz
it can be a broken Ball under µBGA
you need informations about phones life, then you can locate the Problem
Old 06-15-2006, 15:08   #9 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
Yes I know, BUT I WILL SAY IT FOR THE THIRD TIME :
IS THERE IS A TEST TO IDENTIFY THE FAULTY IC ...?
Pls. Help Me Nokia 5200 Dead,UFS is Showing... amit123 Nokia Hardware & Hardware Repair 3 02-16-2011 22:50
pls help me nokia 3500 water damage solanki telecom Nokia Hardware & Hardware Repair 1 01-22-2010 15:37
Pls, help me nokia 3600s, Mxkey'log!!! hoangnam416 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-17-2010 11:31
pls help me !!! nokia 6260 keypad ahsam Nokia Hardware & Hardware Repair 5 01-11-2008 07:54
:rolleyes: :eek: **********PLS HELP ME NOKIA 6600 NEW FLASH FILE THX ALL sunnyc WD2 & APE (Symbian Phones) 2 04-18-2004 07:52
Page generated in 0.24634 seconds with 10 queries
