Old 05-24-2006, 11:58   #1 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
2600 flashing okay but not turn on
i have one 2600 dead.... i try to flash it with ufs.. it complete the flashing but not turn on..... plz help me wot to do with this now....
thanks
Old 06-05-2006, 15:31   #2 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Try to check the power button. Also power it on with the box u r using if ok then surly power button problem
Old 06-05-2006, 19:09   #3 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
Smile
erase flash then flash with good files and write good pm..
if your mobile is not ok then chek power button
Old 06-05-2006, 19:21   #4 (permalink)
Member: 117836
use rh18 1100 fullerase file and reflash the phone with latest version write a good pm and it will be ok
DOOD LUK
Old 07-26-2006, 14:25   #5 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
works 100%
click erase flash then click ok when the starting adrress comes,
and enter this as the end address, after the erase, u can flash with any version and upload pm, it works,
or flash with these filess
sorry my link is dead
Old 07-26-2006, 19:12   #6 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
IF all not work then at last try it .........................as below
1.Put sim card and make it ON u will listen buzzer sound if ur display or its connector is damaged..........................
2.Select 2600 --> Erase --> Start Address 01000000 (Default) --> Change the
End Address 01FFFFFF to 013FFFFF. Now erase the flash area.
Then write MCU and PPM files. Now Phone OK. (GSM 900 Mhz Signal Error).
Write 1100 PM File 34% only (Do not write full pm file). Remove the tick (Un Select) in Autodetect Product.
Select 1100 --> Wr PM --> 1100 pm file --> Stop in 34% . Now phone work with 100% Good Signal.
Old 07-26-2006, 19:24   #7 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
yes i understand..............
but i will try it with another phone.............coz i dont have that mobile with me.....
but thanks for the sugettions......
nice work.... thanks..
Imate JasJar Entering Bootloader mode but not turning on. ZODI. HTC & PDA WM( With Touchscreen) 7 11-15-2008 19:09
2600 flash ok but not powering on aryan_ Nokia Hardware & Hardware Repair 1 09-01-2007 10:20
Alcatel 311 charging but not turning on!!!! agpla BF, BG, TH, BHx Series 3 04-18-2005 11:55
T610, turn off, but not turn on..... PaPiTo Sony Ericsson Hardware Repair 0 01-20-2005 23:05
A800 Flashes, but not turn on. Alex1234 VLSI, Conexant, Skyworks and Old Models 8 10-17-2003 09:03
Page generated in 0.18622 seconds with 9 queries
