Old 05-25-2006, 08:19   #1 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
Arrow Post urs problem here solves in 24 hrs by Javajohn
Hi freinds just post urs hardware problem here i will try to solve it in less then 24 hrs
thanks
Old 05-25-2006, 10:05   #2 (permalink)
chochol's Avatar
Member: 86757
Thanks Meter: 12
N6101 key leds still on.
ONE more details.
1. When I attached the battery only key led´s lights on itself.
2. Led´s of LCD work´s without problems.
3. When I switch off the phone, key leds stay stiil on.
What I allready do:
I meassured all resistor and also this two diode - all looks o.k.
I measured the voltage from UEM on resistor R2400 and it ws 3.6V (not 3.2V)and leds are on is it o.k.?
I dont have this two transistor so I didnt try to exchange,but I trayed to remove this two resistor on line from UEM R2400 and R2419 and leds was off. Thats why I think this transistor are o.k. Am I right?
I think poblem could be in UEM. What do you think.
Old 05-25-2006, 10:07   #3 (permalink)
chochol's Avatar
Member: 86757
Thanks Meter: 12
N3100 phone dead. Imposible to flash.
Hi guys, I have a phone N3100. Phone is dead. I changed UEM and UPP but, I am not able to flash the phone.
I ´tryed to flash with JAF box, but still error message.
I don´t remember exactly the error message but it was something about TX Fbus.
Phone won´t boot.
Phone didnt comunicate with the box. I checked the cable and cable is O.K.
If anybody have the TX and RX FBus ways please share.
Or is it the comboflash memmory? I already reheat the flash, but same result.
Thank´s in advance.
Here are some details:
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__05.540
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__05.54d
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
MCU: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__05.540
Booting phone...
Phone didn't answer with TX line high after power on!
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
This MCU ID is not supported in chosen flash file...
Error booting phone...
Old 05-25-2006, 10:09   #4 (permalink)
Member: 268930
Thanks Meter: 23
Hi fried i Have a problem in Nokia 1600 it no light no screen lights and no keypaid lights pleas sold this and give me solution with picture thanks in advance
Old 05-25-2006, 10:09   #5 (permalink)
chochol's Avatar
Member: 86757
Thanks Meter: 12
N6230 really strange problem.
I have N6230 and I was not able to switch on also when I plug-in the charger it was same. LCD traying starts but only tree times blinking without lighting of leds and after switch off it self.
I tryed to flash the phone everything looks o.k. MCU and PPM flashed o.k., but on the end of the flashing when box trying to start phone same result LCD blinking and box write some error message flashing failed.
Phone booting error.
I tryed to cerfully reheat the TIKU and result ishone is totaly dead - no blinking any more. Whan I try to flash this folowing error message apear.
BOX OK
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
Checking for new firmware and software version...
Getting identity...
Can't get identity...
Suggestion: Check for firewall or try with better internet provider.
Server Error1...
MCU Flash file: NONE
PPM Flash file: NONE
Phone Type:
MCU Flash file: E:\Install GSM\Nokia\flashky\6230\05.40\rh12_28_11005.400
Phone Type:
PPM Flash file: E:\Install GSM\Nokia\flashky\6230\05.40\rh12_28_11005.40d
MCU: E:\Install GSM\Nokia\flashky\6230\05.40\rh12_28_11005.400
Booting phone...
MCU ID: 0x1052
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Loader version: 04.2F.02 -> Revision: 0007
Boot size is 0x2310
Boot is ready...
Error Loading loader!
Do you think, I demaged TIKU when I reheated it?
Could be also previous sympthom (phone doesn´t start but trying to start and blinking) due to TIKU? Or I make a mistake and I reheat wrong component?
Thans for your opinion.
Old 05-25-2006, 10:16   #6 (permalink)
Member: 271079
6101 contact retailer if have sim
for nokia 6101 if have sim card inserted in the mobile it will auto off then on then contact retailer show what to do my friend it has been tampered by other technician (hardware and software)i also flash it with jaf but it same problem hope you can help me thanks!.
Old 05-25-2006, 10:18   #7 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
ONE more details.
What I allready do:
there must be some shorting in urs key leds ways just check it
Old 05-25-2006, 10:20   #8 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
first u must erase and full flash it then if dint work then u have to change flash ic
Old 05-25-2006, 10:21   #9 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
BOX OK
Getting identity...
Server Error1...
Phone Type:
Phone Type:
Booting phone...
MCU ID: 0x1052
Boot size is 0x2310
Boot is ready...
resolder the tiku and flash ic
Old 05-25-2006, 10:23   #10 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
check the leds ways of display connecter on pcb and display both then check the led diode its at the bottom of pcb at front side
Old 05-25-2006, 10:26   #11 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
Phone won´t boot.
Thank´s in advance.
Booting phone...
Causes:
MCU ID: 0xAAAA
u must check urs cable first if ok then check the upp ways
Old 05-25-2006, 11:35   #12 (permalink)
fanbang's Avatar
Member: 73674
Thanks Meter: 91
6230 power on few times then stops power on. have to take it apart and leave it for 10 - 15 mins be it starts power on again. then after 2 - 3 times. i have ti go through the whole process again.
there no sign of liquid damage. ultra sonic it anyway
changed on/off switch
i suspect there might be a short some where, but where?
thanks
br
Old 05-25-2006, 12:08   #13 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
this kind of thread is not very nice for people searching an answer.
best to make a new post for each problem...
Old 05-25-2006, 12:15   #14 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
thanks
br
power on off is not shorting everytime it may software so first try to reflash it and not works then check the uem and on /off switch ways
Old 05-25-2006, 12:17   #15 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
u r right but by this ppls not have to waste there time in different posts if they gets replys in few hrs u can check the time of questions and the answer that how much it takes
Iphone hardware and software solutions in 24 hrs mobitech servic iPhone, iPad, iPod Hardware Repair 6662 10-05-2023 12:18
network problem solved in 24 hrs as_ji Nokia Repair Guide and FAQ 249 09-03-2014 15:13
any mobile or computer problem solve in 24 hours free . sindhi kanu Nokia Base Band 5 ( BB-5 ) 11 12-01-2010 16:50
MT box SonyEricsson problem solved in 24 hor gopalhot Sony Ericsson Hardware Repair 9 06-13-2009 19:49
Page generated in 0.24917 seconds with 10 queries
