Old 09-02-2005, 19:45   #1 (permalink)
Member: 175012
UEM Configuration
hi,
can some1 plz help me,
im buying a UEM chip for my Nokia 6230, but i need to kno what i have to config on it, i kno i need to load a RPL file on it, but what else, and what needs to go on this file,
and one very important question, when you program a new IMEI number in to the chip does it matter which one you put, like what if u accidentally put one thats already in use, would it still work
thanks in advance
Old 09-02-2005, 19:47   #2 (permalink)
Member: 133576
Thanks Meter: 2
Originally Posted by hustler
hi,
thanks in advance
fix uem,then writ a rpl file of 6230(if u want orginel imei u will get rpl file from griffin team or other)
Old 09-02-2005, 19:50   #3 (permalink)
Member: 175012
thanks for replying so quick
i need to program a new IMEI number into the chip, because my old one has been blocked, so do i just choose a random one?, and wht would happen if i accidentally choose the same one as some1 else?
Old 09-02-2005, 21:01   #4 (permalink)
AYMAN SHAMAYLH's Avatar
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
replce uem by anew one
flash ur phone
write pm
choose any working rpl file for 6230
write uem using tornado or twister
ui setting
thats all
if u want ur old imei
read uem
then save file readed
it is in ask
send it to griffin team
u must pay may be one log
then they will send u rpl
write it to ur phone
Old 09-03-2005, 13:07   #5 (permalink)
Member: 175012
ok thankyou you very much "AYMAN SHAMAYLH" that helps alot,
but one last thing that im not sure about is, when you are choosing the IMEI number to program in to the chip does it matter which one you choose, like for instance what happens if you accidentally put one thats already in use, would it still work?
by the way i need to use a different IMEI number not the same as my old one, as my old has been blocked
After removal of glued UEM and glued uem removal video guide Raheeeeb Nokia Repair Guide and FAQ 254 06-19-2019 01:40
Invalid uem checksum, UEM might be damaged ! naveed ali MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-11-2010 16:36
DCTxBB5 2.0.8.5 HWK -> Read UEM OK! Write UEM Failed! [Shadab_M] HWK 3 06-09-2009 07:38
UEM 4376371 IN STOCK FOR UEMe 4376371 For Nokia 7610, 3220, 3230 ETC afacandenis Main Sales Section 0 08-04-2006 15:27
Easier configuration for Nokia flasher Spalato Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-29-2001 22:20
Page generated in 0.17182 seconds with 9 queries
