Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
08-02-2005, 17:14 | #1 (permalink) |
Freak Poster Join Date: Mar 2004
Member: 57254 Status: Offline Thanks Meter: 7 | MOTOROLA V3 dead, only keyboard lights !!?? I have problem with V3 motorola. When push POWER button, only keyboard lights, and nothing happens. Sometimes when I remove and then put back the battery, keyboard lights without pressing power button. Battery is OK, there are no signs of water damage (I open it !) and there are no signs of physical damage of the board. When I put PCB module from another phone (V3), it works (means, displays and tracks are OK). Smart clip does NOT found it when I try to flash it, and it goes NOT in flash mode (* , # i POWER ON). Any sugestion ??!! |
08-02-2005, 20:33 | #8 (permalink) |
Member: 57254 Status: Offline Thanks Meter: 7 | How to put phone in flash mode ? How to flash ? What is force flash cable ? Battery is fully charged on other phone, so it has to be OK !! P.S. If keypad does NOT lights, when I put cable in, it lights ??!! |
08-02-2005, 20:57 | #9 (permalink) |
Junior Member Join Date: Feb 2004 Age: 44
Member: 54126 Status: Offline Thanks Meter: 0 | key light must be on.connect your phone to computer using v3 cable.use the MultiFlashFlex.exe which is in the pst program.this program will automatic turn your phone into flash mode. |
08-03-2005, 11:19 | #14 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 47
Member: 25930 Status: Offline Thanks Meter: 4 | This is 100% sw problem, but i must send to motorola service for repair and only sw. I play with this V3 3 hour and nothing, full battery, USB cable, with flash mode etc and nothig, only error send bootloader to phone..... hrich |
08-03-2005, 11:19 | #15 (permalink) |
No Life Poster Join Date: Mar 2004 Age: 46
Member: 57930 Status: Offline Thanks Meter: 24 | yr phone like to be in flash mode but USB need driver to make a connection but in some case u can`t install driver in flash mode for be sure about cable use old serial cable with connect pins 13&14 i think it is to slow in flash but working without driver but i don`t know what`s program u use wih serial cable ,i think u can use smart-clip and make a serial cable for it GND and RX and TX and shorted pin with RJ-45 i just thinking for solution i didn`t test that |
The Following User Says Thank You to MaFiaaa For This Useful Post: |
After flash moto v3 no display, only keyboard light ! | Unlocker_001 | Motorola P2k | 17 | 06-28-2009 12:19 |
V3 dead only key pad light | irfaN_vu | Motorola Hardware Repair | 11 | 12-24-2007 20:52 |
v3 dead only keypad light | mory2 | Motorola P2k | 10 | 11-20-2007 14:28 |
HELP V3 only keyboard lights up | ticktock | Smart-Clip | 4 | 01-14-2006 17:58 |
samsung z500 dead, only keyboard lights !!?? | TITO | QUALCOMM Models (3G) | 11 | 12-02-2005 13:00 |
