Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 08-02-2005, 17:14   #1 (permalink)
Member: 57254
Thanks Meter: 7
MOTOROLA V3 dead, only keyboard lights !!??
Hi !!!
I have problem with V3 motorola. When push POWER button, only keyboard lights, and nothing happens. Sometimes when I remove and then put back the battery, keyboard lights without pressing power button. Battery is OK, there are no signs of water damage (I open it !) and there are no signs of physical damage of the board. When I put PCB module from another phone (V3), it works (means, displays and tracks are OK). Smart clip does NOT found it when I try to flash it, and it goes NOT in flash mode (* , # i POWER ON).
Any sugestion ??!!
Old 08-02-2005, 17:22   #2 (permalink)
Bert's Avatar
Member: 596
Sonork: 100.33096
Thanks Meter: 514
you did try with the force flash cable?
Old 08-02-2005, 17:33   #3 (permalink)
Member: 25930
Thanks Meter: 4
What is force flash cable? I have same problem with one V3...
thanks
hrich
Old 08-02-2005, 17:49   #4 (permalink)
Member: 34845
the baterie is full charged???? i have de same problem in mpx220. baterie is 1/2 and the phone donīt power on ..when i put a full baterie the phone is alive again :d
Old 08-02-2005, 18:01   #5 (permalink)
Member: 25930
Thanks Meter: 4
My friend battery full is first step for repair......with full battery same problem
hrich
Old 08-02-2005, 19:58   #6 (permalink)
Member: 54126
try to flash with newer version it might works.i had same problem before and i fixed it.
remember v3 not allow to downgrade.
Old 08-02-2005, 19:58   #7 (permalink)
TIENPHAT's Avatar
Member: 121801
i same to you,you try chan flash cable!
Old 08-02-2005, 20:33   #8 (permalink)
Member: 57254
Thanks Meter: 7
How to put phone in flash mode ? How to flash ? What is force flash cable ?
Battery is fully charged on other phone, so it has to be OK !!
P.S. If keypad does NOT lights, when I put cable in, it lights ??!!
Old 08-02-2005, 20:57   #9 (permalink)
Member: 54126
key light must be on.connect your phone to computer using v3 cable.use the MultiFlashFlex.exe which is in the pst program.this program will automatic turn your phone into flash mode.
Old 08-02-2005, 20:59   #10 (permalink)
Member: 54126
once again this program must use usb cable
Old 08-02-2005, 21:03   #11 (permalink)
Member: 54126
when you put cable in, it lights.it means battery in charge.it's normal
Old 08-02-2005, 21:42   #12 (permalink)
Member: 8832
v3
try to change flex cable
Old 08-03-2005, 11:05   #13 (permalink)
Member: 57254
Thanks Meter: 7
I'll try this solution and post results !
Thanks !
Old 08-03-2005, 11:19   #14 (permalink)
Member: 25930
Thanks Meter: 4
This is 100% sw problem, but i must send to motorola service for repair and only sw. I play with this V3 3 hour and nothing, full battery, USB cable, with flash mode etc and nothig, only error send bootloader to phone.....
hrich
Old 08-03-2005, 11:19   #15 (permalink)
MaFiaaa's Avatar
Member: 57930
Thanks Meter: 24
yr phone like to be in flash mode
but USB need driver to make a connection but in some case u can`t install driver in flash mode
for be sure about cable use old serial cable with connect pins 13&14 i think
it is to slow in flash but working without driver but i don`t know what`s program u use wih serial cable ,i think u can use smart-clip and make a serial cable for it GND and RX and TX and shorted pin with RJ-45 i just thinking for solution i didn`t test that
The Following User Says Thank You to MaFiaaa For This Useful Post:
[IMG] code is Off
After flash moto v3 no display, only keyboard light ! Unlocker_001 Motorola P2k 17 06-28-2009 12:19
V3 dead only key pad light irfaN_vu Motorola Hardware Repair 11 12-24-2007 20:52
v3 dead only keypad light mory2 Motorola P2k 10 11-20-2007 14:28
HELP V3 only keyboard lights up ticktock Smart-Clip 4 01-14-2006 17:58
samsung z500 dead, only keyboard lights !!?? TITO QUALCOMM Models (3G) 11 12-02-2005 13:00
Page generated in 0.23517 seconds with 9 queries
