04-04-2009, 08:36 | #1 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1004259 Status: Offline Thanks Meter: 2 | LG Neon - TE365 (KS360) - Fido branded (custom mp3 ringtones disabled) I quickly discovered that Fido/Rogers has disabled the use of custom MP3 ringtones, which, to put it bluntly, ***** big time. I am on a quest to find a way to enable custom MP3 ringtones. It seems my best bet would be to flash the firmware to European unbranded QWERTY KS360 firmware, though I will lose the use of the 850mhz band. Does anyone know if switching to the European unbranded firmware will allow one to set custom MP3s as ringtones and sounds? I've been looking all over online and I haven't been able to find too much yet about enabling custom MP3 ringtone use on the LG Neon (TE365), because it has only been out for a little while. This is actually a big problem here in Canada. Tons of people are pissed about how Fido is blocking the use of custom MP3 ringtones on the LG Neons. And so far there is no solution that can be found anywhere online. It is my hope that this thread will generate some activity and be host to a working solution, and all who are looking online for a solution to this may find it. I would be interested to hear from anyone else who is currently working in this direction as well, or from some of you who might have already accomplished this. bombadil |
The Following User Says Thank You to bombadil For This Useful Post: |
04-18-2009, 00:27 | #2 (permalink) | |||
Insane Poster Join Date: Oct 2002 Location: Toronto, Canada
Member: 16314 Status: Offline Thanks Meter: 8 | Quote:
Yes, tested by us. Flashing the TE365 with KS360 firmware works but remember to fix IMEI as it gets corrupted when flashed. Keep in mind you need KE500 cable NOT KG800. After, direct unlock the phone. You will however lose your 850MHz and this was tested also by us with our Rohde & Schwarz CMU200. There seems to be a quad band chip on board and is controlled by the firmware. Our guess is we can flash KS360 with TE365 and it will disable 900MHz but add 850MHz. Will test later. | |||
The Following User Says Thank You to bongowireless For This Useful Post: |
04-18-2009, 01:08 | #3 (permalink) |
Freak Poster Join Date: May 2003 Location: Oh! Canadadadada
Member: 29398 Status: Offline Thanks Meter: 1 | for the flashing part you can use KG800 cable but you have to use ke500 RJ45 box cable to do the imei fix, in my place ppl is ok with only 1900 band so there is no problem |
The Following User Says Thank You to jacsha For This Useful Post: |
04-18-2009, 16:57 | #4 (permalink) | |
No Life Poster Join Date: May 2002 Location: Canada Age: 97
Member: 12270 Status: Offline Thanks Meter: 107 | Quote:
850MHz is so important in my area that customers wouldn't even consider losing 850 to gain mp3 as a ringtone. | |
The Following User Says Thank You to hafftrak For This Useful Post: |
04-23-2009, 19:29 | #5 (permalink) |
Member: 1016590 Status: Offline Thanks Meter: 1 | Hey guys I just got the Neon today. Was wondering if you can post step by step instructions on how to unlock and flash the firmware to European unbranded QWERTY KS360 firmware ??? I've always bought unlocked phones but now I have to do it myself i guess haha Also what does losing the use of the 850mhz band mean ? Is that Internet access? Thanks so much in advance |
The Following User Says Thank You to Cyntia For This Useful Post: |
05-25-2009, 08:00 | #8 (permalink) |
Junior Member Join Date: May 2009
Member: 1038558 Status: Offline Thanks Meter: 2 | how do you know which frequencies you need or don't need? because I really want to unlock my Neon but I'm worried about losing the 850 range. also how do you repair the IMEI? is there a chance that it might get corrupt (irreparable)? really appreciate the help!! |
The Following User Says Thank You to robomatic For This Useful Post: |
06-02-2009, 05:40 | #9 (permalink) | |
Member: 1038558 Status: Offline Thanks Meter: 2 | Quote:
anyone? anyone? anyone? anyone? anyone? anyone? anyone? anyone? anyone? anyone? anyone? | |
06-02-2009, 22:16 | #10 (permalink) | ||
Junior Member Join Date: Jun 2009
Member: 1044579 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to adnix For This Useful Post: |
06-13-2009, 00:56 | #11 (permalink) |
Member: 1051641 Status: Offline Thanks Meter: 0 | I live in Vancouver and I am scared what will happen if I DO lose the 850mhz band. I think I can still use the 1900 mhz one but when i get into elevators and basements the sig mite not be as clear... Anyone tried this in vancouver yet? |
06-18-2009, 18:44 | #12 (permalink) |
Blocked Join Date: Jul 2005 Location: Jamaica Age: 41
Member: 162707 Status: Offline Thanks Meter: 66 | HI Which software do you use to fix the imei? I have flashed my TE365 to KS360 works but imei is corrupt I don't know how to repair the imei please I am awaiting your speedy response. Venom fr Jamaica |
01-23-2010, 02:57 | #14 (permalink) |
Member: 1004259 Status: Offline Thanks Meter: 2 | Update ! Here is how to set custom ring tones !!! Hi all, I recently discovered how to set custom MP3 ringtones on this phone with NO MODIFICATION. Just check out this youtube video: http://www.youtube.com/watch?v=uGCGkZKafJ8 It's a secret feature (or bug) built into the phone OS ! Hope this helps bombadil |
Un-Branding AT&T LG Neon GT365 | h22turbo | LG | 9 | 02-07-2010 12:39 |
how to enter unlock code for LG NEON | footyredviz | LG | 1 | 01-11-2010 20:20 |
Lg neon te365f unlock request | ansarirashidy2k | Infinity-Box | 0 | 10-27-2009 05:24 |
LG Neon TE365 (KS360) - Unable to sync | adnix | LG | 0 | 06-02-2009 21:14 |
LG u880 - Mp3 ringtones? | Greatgonzo | LG | 4 | 12-28-2005 00:43 |
