Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
02-07-2003, 18:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Eeprom Tools V 4.0 Released What's new: - This version has the ability to change or rebuild IMEI number removed. If you are in UK or country that prohibit altering the IMEI number of GSM handsets by law and you still use older version of Eeprom Tools, please delete them from your HD and use the provided version. - New MBUS/FBUS comunication API layer provide more stable behaviour of the program and allow XP compatibility. - Read Start Up Self Test has separate Form Window and show all tests not the Failed only. - Left button is only to read phone info, the padlock is to rebuild default SP data in eeprom (dct3), and the right one will update FAID. - DCT4 Logger Mode - checking the 'Logger' box will allow to use Eeprom Tools for a DCT4 SP rebuild. Needed cable is FBUS ( all DCT3 functions require Mbus), or F/Mbus dual switching cable. * Supported DCT4 handsets: - 8310 - 6510 - 8910 - 8910i - 3510 - 3510i - 7210 - 6610 - 6100 - 7650 - 3650 - 6800 - 5100 ... etc. * Please check the Readme.txt for more details how to use this function. You can use now your old DCT3 dual switching cable for all DCT3 and DCT4 handsets - simply change the connector with the needed one and play with the RTS/DTR check boxes till you make it to work in the required connection mode. Please feel free to download from our website. Best Regards, Alex |
02-07-2003, 19:34 | #7 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: UK
Member: 2868 Status: Offline Thanks Meter: 514 | Hi, Quote:
www.b-phreaks.co.uk Best regards Daniel | |
02-08-2003, 01:04 | #9 (permalink) |
Freak Poster Join Date: Mar 2002 Location: LONDON UK Age: 41
Member: 9857 Status: Offline Thanks Meter: 0 | Pointer To Not Supported Hash Table Hello M8's What Does This Mean ? When I Run This Programme I Connect to Com 1 and The Then Click Read Info And This Is The Message I Get. What Does It Mean ? "Pointer To Not Supported Hash Table" ?? Best Regards Adam Rest Vast Gsm Team |
02-08-2003, 02:01 | #11 (permalink) |
No Life Poster Join Date: Jun 2002 Location: England
Member: 13335 Status: Offline Thanks Meter: 2 | hi m8 whenever i go on www.b-phreaks.co.uk i get Server Error in '/' Application. -------------------------------------------------------------------------------- Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine. Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off". < !-- Web.Config Configuration File -- > < configuration > < system.web > < customErrors mode="Off"/ > < /system.web > < /configuration > Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. < !-- Web.Config Configuration File -- > < configuration > < system.web > < customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/ > < /system.web > < /configuration > btw ive put spaces in between < and command > so u can see it |
02-08-2003, 05:51 | #12 (permalink) | |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Re: Pointer To Not Supported Hash Table Quote:
This is error caused by reading the MSID from the phone or the MSID is simply not valid. To Face Off Mobile: Could it be some .Net compatibility issue with your browser ? Will have to ask our webmaster, since this is not my stronger side. Here the download link, I hope will work: http://www.b-phreaks.co.uk/downloads/EepromTools.zip Best Regards | |
02-08-2003, 06:14 | #13 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: mumbai Age: 54
Member: 7889 Status: Offline Thanks Meter: 7 | Quote:
u was the first to rebuild imei on dct3 by log method thanks to all your team | |
02-08-2003, 11:45 | #14 (permalink) |
No Life Poster Join Date: Dec 2002 Age: 57
Member: 18965 Status: Offline Thanks Meter: 3 | help with eeprom tools v4 i am new to all this what can this v4 software do.... can some tell how to use it ect..... can it unlock old dct3 and dct4 ???????? please reply..................... |
10-08-2007 Again new updates! Philips Tool v.11 and MTK tool v.4.0 - released! | GSMtricks | Multi-box LITE | 1 | 01-15-2013 05:57 |
06-06-2008 New Spreadtrum tool v.1.0 released FULL Service tool! New Chinese cocktail | GSMtricks | Multi-Box | 14 | 06-10-2008 14:47 |
06-06-2008 New Spreadtrum tool v.1.0 released FULL Service tool! New Chinese cocktail | GSMtricks | Multi-box LITE | 17 | 06-08-2008 13:05 |
10-08-2007 Again new updates! Philips Tool v.11 and MTK tool v.4.0 - released! | GSMtricks | Multi-Box | 9 | 08-13-2007 12:43 |
