Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 03-18-2007, 23:23   #31 (permalink)
Member: 299758
please pinouts cable for flashing gx 29 , user cable nec 3g , problem instaled driver ... thanks
Old 03-25-2007, 10:36   #32 (permalink)
Member: 322417
Thanks Meter: 940
Angry
don't spam the board with FOOLISHNESS
the 17 flasher do not work that fuc..rs that say work wasted my time on the forum........ok
for the last time flasher do not work maybe they have some nother problem and phone alive but the resason is not flasher
Old 04-09-2007, 13:40   #33 (permalink)
Member: 460086
Thanks Meter: 37
tested goooooood woooooork
thanks........
Old 04-18-2007, 23:09   #34 (permalink)
glontz's Avatar
Member: 16269
Sonork: 1604924
Thanks Meter: 62
i need flash sharp gx29 200612
Old 04-19-2007, 09:54   #35 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
Oooooooooooooooohhhhhhhhhhhhhh Please!!!!!!!!!!!!!!!!!!!!!!! Gx17 Doesnīt Work On Gx29!!!!!!!!!! This Is A Waste Of Time!!!!!!!!!!!!!!!!!! U Canīt Flash Fully A Gx29 With Gx17 Flasher Of Platijet!!!!!!
Old 04-19-2007, 12:45   #36 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
And this is the Reality
Gx17 Flasher not same as Gx29
Ask Platijet Why!
Old 04-23-2007, 01:55   #37 (permalink)
Member: 204759
Gx 92 Cable
I HAVE MOFIFIED MY CABLE TO MAKE CHRGE MY GX29
BUT WHEN I CONNECT IT TO COMPUTER IT IS CHARGEING AND I CAN SEE THE USB ICON THE DISPLAY BUT THE COMPUTER SAYS
UNKNOW DIVICE I TRY TO INSTALL DRIVER BUT WITH NO LUCK
WHEN I CONNECT THE PHONE WITH OUT BATTRIES IT SHOW AS A UNKNOWN DEVICE BUT GO OFF WHEN I TRY TO INSTALL DRIVERS
WHAT MUST I DO , I HAVE DOWNLOAD THE DRIVERS FOR PHONE IN THIS SITE AND I HAVE DOWNLOAD MODEM DRIVERS BUT CAN
T GET PASS UNKNOW DEVICE . HELP HELP
Old 04-23-2007, 01:56   #38 (permalink)
Member: 204759
Gx 29 Cable
Old 04-23-2007, 22:41   #39 (permalink)
Member: 204759
Gx 29
I HAVE FOUND THE SOLUTION I CONNECTED THE D- AND D+ ON THE USB CABLE USB BACK WAYS , NOW I HAVE CONNECT THE PHONE WITHOUT BATTRIES AND INSTALL FLASH DRIVERS
Old 04-25-2007, 06:40   #40 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
olds scraap but working as well ...
Old 07-10-2007, 23:53   #41 (permalink)
Member: 104927
Thanks Meter: 60
Solution to unlock Sharp GX29
Hello all
I have unlocked a 200606 gx29 from vodafone spain with those files and with the next proedure. So, here we are:
Software is the Albelektronik team gx17-gx29 flasher
Full flash is here: gx29
and folow the specifications from the atached image. All of you, have to do is flash the phone, without batery, with the files selected, using a NEC E8 cable, just like the specifications from the image.
Reply problems...
The Following User Says Thank You to sokettro For This Useful Post:
Old 08-06-2007, 11:48   #42 (permalink)
Member: 240778
Thanks Meter: 3
i have.GX29 200610.DEAD.I FLASH IT WITH PLATIJIT.RESULT OK.BUT NO TRANSMISSION.HE RESTART IN CALL.CAN SOME ONE HELP ME.OR IF SOME ONE HAVE VODAFONE FILES 200610.THANKS.
Old 08-17-2007, 13:32   #43 (permalink)
Member: 104927
Thanks Meter: 60
Hello.
Try to flash your phone completly with the files posted above and might work. I flashed a gx17 200707 with a complete firmware from another gx17 made on 200702 and works. Check if you have the drivers corectly instaled and use the software from albelektronik, may be useful. After that, if you will have the same problem again, send me a ymsg, i will try to help you.
Old 08-19-2007, 19:20   #44 (permalink)
jakrzys's Avatar
Member: 118554
Thanks Meter: 74
And where is flasher and drivers???
Old 08-20-2007, 14:44   #45 (permalink)
Member: 104927
Thanks Meter: 60
http://forum.gsmhosting.com/vbb/show...5&postcount=42
sharp gx29 flash ok not power on Formingus Sharp 31 06-02-2014 19:16
sharp gx29 flash ok not power on Formingus Sharp 1 02-20-2007 12:26
I am lookinf for GX29 flash + flasher !! makroud Sharp 13 02-19-2007 14:16
Sharp Gx29 Flash Procedure yoni93320 Sharp 11 02-08-2007 16:14
Page generated in 0.24072 seconds with 10 queries
