06-11-2005, 22:25 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 45
Member: 119496 Status: Offline Thanks Meter: 0 | Gx30 Help http://www.unlockeasy.com/modules.ph...ownload&cid=38 now, if u go right to the bottom and download the LAST SOFTWARE available for sharp phones, you see theres a unlocker for gx15 gx30 tm100. if you have a mess around on that and look at the PORTS its says USB i am not sure if it works or not but could someone give some insight on it? also...i have a sharp 902 and a gx30I, WHICH SOFTWARE was the best to use for SHARP gX30? Furios Dongle Cracked is what i been told to use, but i do not have a clue about how to use it (the cables required and how to generaly use it -> it stops at 3% when i use it)..could someone recommend to me what is the best software to use using a SERIAL CABLE? what software is the best to use with a USB CABLE (if there is a way unlock with usb!) thanks |
Can't enter in diag. mode GX30 HELP!!! | moldovan | Redbox | 7 | 10-26-2004 18:55 |
Can i use Gx30 Usb cable to Unlock Gx30, Tm100 with Red box ?? | Aamir_Zia | Redbox | 3 | 10-07-2004 08:03 |
continued... GX30!! help.. | Ped | FuriouS II | 2 | 09-24-2004 10:09 |
GX30 Help Please | frostbite | Sharp | 3 | 09-09-2004 02:09 |
Sharp Gx30 Need help witj unlock | tattarn | Sharp | 22 | 05-27-2004 11:36 |
