VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
06-07-2003, 06:11 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Look like you have N105 wrong flashed to N100 or N108... or eeprom IC is damaged and short I2C lines. Try to change eeprom IC with new one (programed with N105 dump!) - if work - well - if not - then it's not so easy to repair wrong flash |
06-08-2003, 00:22 | #4 (permalink) | ||
Administrator Join Date: Jul 2002 Location: E G Y P T Age: 38
Member: 14178 Status: Offline Thanks Meter: 8,862 | Quote:
well that the 1st phone i see it not easy at all to get another one and working , mabe lets get to the hard way i have to repair it Quote:
and with the sim in i get contact provider i get ( as i think ) i flash for the phone but it stubid under dos program never works i tryed to up load the axf and the ogm useing other programs still no resuilt the program detect the phone but can't read phone ID . | ||
06-08-2003, 07:03 | #5 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Hint - just take out eeprom IC (24c256 or some analog) and see what happened - if you win power on without to hold pressed power key (in this case - low contrast and "contact provider" on screen, but this it's not so important!) - then problem for sure is in eeprom IC - write me private - i will send to you good dump to rewrite new IC. If still need to hold power pressed - then for sure you have wrong flashed N105 to N100 or N108 - you need to find NEW flash IC, change in phone and reflash. |
06-08-2003, 17:27 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Viet Nam Age: 49
Member: 5487 Status: Offline Thanks Meter: 5 | Hi I known that is your fone have 2 problem now. - Press power and it work. But when you release it off is wrong in flash. So may be 1 people try to flash N100 or N200 to it. It will have that problem. So for FIX this problem only REPLACE NEW FLASH and re flash it by Origine N105 flash file. - When it power on and say " contact provider.." it mean wrong in EEPROM may be it now is blank eeprom so you must write new contain to it. Or replace new eeprom but I don't think your eeprom is wrong. And may be it SHort SDA and SDL to GND and it say "contact provider " too try to clean bottom syatem connector it will ok. If you need origine flash file for N105 and good eeprom file try contact me I'll send to you. best regards |
06-11-2003, 19:18 | #8 (permalink) |
Freak Poster Join Date: Apr 2003
Member: 26422 Status: Offline Thanks Meter: 1 | Samsung N105 Flash file & Eeprom Pls. I have this same problem. Pls. can you send me N105 flash file and eeprom. Thank you for your help. [email protected] |
08-03-2003, 17:33 | #13 (permalink) |
No Life Poster Join Date: Apr 2002 Location: egypt Age: 54
Member: 11101 Status: Offline Sonork: 100.1641000 Thanks Meter: 1,783 | u will find s105 flash in www.gsmegypt.com |
x480 water damaged.... to power on have to keep power button pressed | Burnt Cobba | Samsung Hardware Repair | 2 | 03-21-2006 17:08 |
are any one have solved for K608 to worked to 2G its only worked to 3g | gsm4libya | Cruiser Suite | 0 | 01-22-2006 16:24 |
8850 doesnt hold power,cuts off during calls!!! | reo | Nokia Hardware & Hardware Repair | 10 | 05-30-2002 21:44 |
T18 Must Hold Power ON.. | j2000 | Hardware Repair by brands | 12 | 02-19-2002 02:37 |
T18 Must Hold Power ON | j2000 | Old Ericsson Phones & Sony Phones | 8 | 12-24-2001 23:13 |
