Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-20-2018, 09:49 | #316 (permalink) | |
Freak Poster Join Date: Mar 2013 Location: In your Mind Age: 35
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | Quote:
03-22-2018, 07:36 | #318 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2821815 Status: Offline Thanks Meter: 0 | Sadly that torrent is dead. Also, that is the arabic file? This is the US model? Thank you anyway! Still auth error so method patched, along with all others? Can confirm remote FRP removal is viable? say paid service? Thanks for all help anyway! |
03-22-2018, 08:05 | #319 (permalink) |
Freak Poster Join Date: Dec 2008 Location: uae.abudhabi
Member: 930738 Status: Offline Sonork: 100.1652204 Thanks Meter: 8 | Samsung S8/S8 Plus 100% Working FRP SOLUTION 2018 https://www.youtube.com/watch?v=Yss4MfnvEXk |
03-23-2018, 21:43 | #321 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | Quote:
for this it working 100% | |
03-28-2018, 10:40 | #324 (permalink) |
Insane Poster Join Date: Jun 2007 Location: RWANDA/ GISENYI
Member: 523082 Status: Offline Thanks Meter: 9 | o begin with, You need to flash combination, after that flash from normal firmware only system+sboot+boot+recovery+cache. I succeded this by only using OCTOPUS. 1. I flashed Combination then selected all flashfiles : BOOT, AP, CP, and CSC (HOME) after I only selected: system+sboot+boot+recovery+cache. its done successfully. NB: Dont forget to specify on octopus that u want to use original flashfile instead of octopus 1. |
The Following 2 Users Say Thank You to imamuka For This Useful Post: |
04-01-2018, 02:24 | #326 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2146504 Status: Offline Sonork: medd303 Thanks Meter: 0 | Have 2 phones samsung S8 plus android 7 Nougat , every one have an issues tooooo confused # G955u , succes flashing combination and can't flashing the Rom untill the phone is dead can't open it again , and now im mood HS-USB QDloader 9008 =====> I'm still confused with that issue , i not found the qualcomm files for S8 plus G955u . # G955N , Failed while flashing comination , get error while used Odin and octoplus box I think that problem because should enable USB Debugging Mode , But i dont know how to Enable it , and the phone is locked even I tried Headset phone ( *#0808# ) Plzzzzz HEEEEEEELP for any Solution Guys |
