Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 05-16-2018, 10:02   #346 (permalink)
Member: 253594
Thanks Meter: 5
Originally Posted by elaygenov View Post
try one of the
this is your COMBINATION_FA70_G955FXXU1ARA1.zip2
where can i download this software?
The Following User Says Thank You to GSM WORLD For This Useful Post:
Old 05-16-2018, 13:26   #347 (permalink)
Member: 2255884
Sonork: 1667608:OMAR
Thanks Meter: 35
It Was Just An Example
Sent from my SM-G570F using Tapatalk
Old 05-21-2018, 11:47   #348 (permalink)
Member: 2838041
dear friends please suggest video i want to know how to doing software in samsung android mobile
Old 05-22-2018, 07:24   #349 (permalink)
Member: 2709932
Need g950w combination file that can bypass frp on android 8.0
Old 05-22-2018, 20:00   #350 (permalink)
Member: 2804811
Thanks Meter: 13
Samsung S8 / S8+ FRP Lock Remove 100% Done.
First You flash combination File.
after flash from firmware only system+sboot+boot+recovery+cache by z3x box / octopush box.
The phone need 15 min to boot up then only click next-next-next or
swipe from up the notification bar and go to setting then to enable
OEM and make hard reset.
If your phone still boot hang on logo just re-flash sboot + boot by z3x box / octopush box.
Combination files download from here:
SM-G950F/FD : https://drive.google.com/file/d/0B1Q...o3bDVhQ3c/view
SM-G955F/FD : https://drive.google.com/file/d/0B1Q...hBd2Iwd2s/view
SM-G950U : https://drive.google.com/file/d/0B1Q...lyNWRpR1U/view
SM-G955U : https://drive.google.com/uc?id=0B1Qv...xport=download
Full firmware download from here:
SM-G950F/FD : https://drive.google.com/file/d/0B1Q...Nnd1huODQ/view
SM-G955F/FD : https://drive.google.com/file/d/0B1Q...E2UDNqaG8/view
SM-G950U : https://drive.google.com/file/d/0B7R...VDRWFPOVU/view
http://www.youtube.com/watch?v=BwuySygRc24
The Following 5 Users Say Thank You to Rightchoose For This Useful Post:
Old 05-28-2018, 14:19   #351 (permalink)
Member: 331337
Thanks Meter: 72
Hi any solutions for unlock frp on s8 g950f and s8 plus g955f 8.0 ?
Old 05-28-2018, 20:07   #352 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
1 post above yours...
Old 05-29-2018, 04:23   #353 (permalink)
Member: 2137564
Thanks Meter: 32
keep it up ,, working in g950f
need to use odin latest version
Old 06-01-2018, 02:48   #354 (permalink)
Member: 331337
Thanks Meter: 72
Hi any solution for frp unlock on G955w on 8.0 firmware . Please help
Old 06-03-2018, 16:40   #355 (permalink)
Member: 2495115
Thanks Meter: 34
Thanks to all experts above
This is my route to FRP removal
G950f
  1. Flash with combination file above useing Z3X
  2. enable ADB, oem unlock not available
  3. Flash original firmware useing Chimera, but only system,sboot,recovery and cache
  4. When phone restarts go to dev options and allow OEM unlock and then factory reset
  5. ALL DONE!!!!!
Again many thanks to earlier posters
Steve
The Following User Says Thank You to Stevefilby For This Useful Post:
Old 06-04-2018, 22:50   #356 (permalink)
evasoft's Avatar
Member: 515830
Thanks Meter: 80
can anyone share bit3 combination g955u1? thanks
Old 06-05-2018, 14:24   #357 (permalink)
Member: 2442503
Hello, can I give Combination files G950FXXU2?
Old 06-07-2018, 14:09   #358 (permalink)
Member: 52032
Thanks Meter: 4
Take a look in z3x support
Old 06-07-2018, 20:36   #359 (permalink)
Member: 2464187
Thanks Meter: 3
Hello,
Just managed to remove FRP from Samsung G955U S8+ from TMO with security patch from april 2018 and android 8.0 Oreo installed.
process that i followed was:
1.- Flash Combination u3ARD1 (this phone came with binary 3)
2.- Wait till the gears image fades and appears the main menu, proceed then as usual. (Settings, enable developer, enable OEM, and restore phone)
3.- Once done, leave it to fully boot then enter once more to the Download Mode, FRP should be OFF now.
4.- Flash G955USQU3CRD4_OYN3CRD4 (both combi and FW are in Z3X support files)
5.- Unlock with Z3X pro G955U using unlock via TMO Server
6.- Get a cold beer and enjoy the phone.
The Following User Says Thank You to alterr666 For This Useful Post:
Old 06-10-2018, 05:26   #360 (permalink)
Member: 901949
Thanks Meter: 50
what if the enable OEM menu is not showing up
Page generated in 0.24776 seconds with 9 queries
