Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 04-08-2018, 09:19   #331 (permalink)
Member: 2018487
Thanks Meter: 2
will this work on Oreo? anyone tried?
Old 04-10-2018, 13:39   #332 (permalink)
Member: 2387344
Thanks Meter: 37
Samsung S7 Edge Firmware Download
https://www.allflashfiles.net/2015/0...-software.html
Regards: Allflashfiles
Old 04-12-2018, 14:26   #333 (permalink)
Member: 1057416
Thanks Meter: 9
Originally Posted by imamuka View Post
o begin with, You need to flash combination, after that flash from normal firmware only system+sboot+boot+recovery+cache.
I succeded this by only using OCTOPUS.
1. I flashed Combination then selected all flashfiles : BOOT, AP, CP, and CSC (HOME) after I only selected: system+sboot+boot+recovery+cache.
its done successfully.
NB: Dont forget to specify on octopus that u want to use original flashfile instead of octopus 1.
Successssssssssssssssssssss 100%
Old 04-13-2018, 21:45   #334 (permalink)
Member: 2691997
Thanks Meter: 2
I have G955FXXU1AQK7
wich COMBINATION and original flash to use plz help
SM-G955F 39.13 Gb
COMBINATION_FA70_G955FXXU1AQCB.zip11
COMBINATION_FA70_G955FXXU1AQD7.zip11
COMBINATION_FA70_G955FXXU1AQF1.zip9
COMBINATION_FA70_G955FXXU1AQI1.zip5
COMBINATION_FA70_G955FXXU1ARA1.zip2
G955FXXU1AQCA_OXM1AQCA.zip11
G955FXXU1AQDD_ODX1AQD3.zip11
G955FXXU1AQDD_VNZ1AQDD.zip11
G955FXXU1AQDD_XSA1AQDD.zip11
G955FXXU1AQF7_ODX1AQF1.zip9
G955FXXU1AQF7_OXM1AQF7.zip9
G955FXXU1AQH3_OXM1AQH3.zip7
G955FXXU1AQI7_OXM1AQI7.zip5
G955FXXU1AQJ5_OXM1AQJ5.zip5
G955FXXU1AQL5_OXM1AQL5.zip3
Old 04-13-2018, 23:05   #335 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 85
try one of the
this is your COMBINATION_FA70_G955FXXU1ARA1.zip2
The Following User Says Thank You to elaygenov For This Useful Post:
Old 04-13-2018, 23:05   #336 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 85
I have made a test my self and its working fine
Old 04-14-2018, 07:07   #337 (permalink)
Member: 2782332
Thanks Meter: 185
just bypass success with samsung s8+ (SM-G955FD) (G955FXXU1CRAP) android 8.0 orea with security february 2018
my case is when the ask for google account..just type any letter (abcd)press longer u can see a options with map..
if u see this option or u can use any method to login browser and if u want solution pls pm me
Old 04-14-2018, 07:22   #338 (permalink)
Member: 2782332
Thanks Meter: 185
Old 04-14-2018, 10:36   #339 (permalink)
Member: 2782332
Thanks Meter: 185
please try after hard reset wipe all data and cache and connect with wifi within 5 minutes...b4 google playstore auto updating..
Old 04-16-2018, 15:45   #340 (permalink)
Member: 2332823
Sonork: 100.1662161:modern-mobile
Thanks Meter: 463
technocare
Old 04-20-2018, 00:23   #341 (permalink)
Member: 2188956
Thanks Meter: 29
the QK5 firmware does not have sboot
Old 04-22-2018, 20:29   #342 (permalink)
Boshko_Alfa's Avatar
Member: 472933
Sonork: 100.1590967
Thanks Meter: 1,331
i have corumpted G955F with erased EFS, need to remove FRP to install TWRP for fixing dm-verity/efs problem.
When i try to flash Cumston Binary - only stay on custom binary logo and the narrows going, tried with lot of roms and custom binary/factory images but w/o sucess any suggestion?
Old 04-22-2018, 21:20   #343 (permalink)
Member: 2255884
Sonork: 1667608:OMAR
Thanks Meter: 35
Originally Posted by jeelani422 View Post
not working .....with combination file.
Just Try Latest Combination ,
E.X - You Should Go First Phones Recovery Mode ,Then Find Firmware Version , Find Same Security Combination Such As
G928CXXS4CRA1
After Done Via combination (Full) Wait 5 Min Phn will Run Autometically
Do Factory Reset
Then Flash with original Firmware Without Usar data
You Will Done
If Work Dont Forget Thanks
Sent from my SM-G570F using Tapatalk
Old 04-22-2018, 21:28   #344 (permalink)
Member: 2255884
Thanks Meter: 35
Originally Posted by Heiner51 View Post
Hellao at all...
What is with the languages when i use the arabic Firmware. Change it the language in each area on the Device. When i use it for an European devices!?
OJV
Old 04-22-2018, 21:51   #345 (permalink)
Member: 2255884
Thanks Meter: 35
Originally Posted by Albelektronik View Post
Hello Everyone,
i can access setting and developer menu but there is not OEM lock there to turn ON or OFF
Any idea?
Regards, Carmelo.
Just Factory Reset And Than Full Flash with Latest Stock Rom Without Usar Data
You Will be Done
Dont Forget To Thank
Page generated in 0.20251 seconds with 9 queries
