Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
11-11-2017, 13:21 | #199 (permalink) |
No Life Poster Join Date: Jan 2012
Member: 1713296 Status: Offline Thanks Meter: 67 | Wondering if this solution work on my SM-G950F because showing both locks ON in download mode, OEM lock : ON FRP lock : ON Can I use this combination file to remove FRP? Just curious to avoid any further problem in future, kindly guide me ASAP ,thanks |
11-14-2017, 18:19 | #200 (permalink) |
Junior Member Join Date: Nov 2006
Member: 397678 Status: Offline Thanks Meter: 4 | Flash Combination File 1. Open Z3X SamPro, select model G955F and go to Flash tab 2. Connect phone in download mode: Vol+,BixbyButton and Power, then vol+ 3. In the "Phone" line select the Combination file : COMBINATION_FA70_G955FXXU1AQDB_Halabtech.tar and flash 4. The phone will restart a couple of times and then reboot to a "FACTORY BINARY" menu, switch off Flash Normal Firmware 5. Set phone in download mode again 6. Select BOOT: BL_G955FXXU1AQDG_CL11168760_QB13362118_REV00_user_ low_ship Click three dots on the right and select only "sboot.bin" PDA: AP_G955FXXU1AQDG_CL11168760_QB13362118_REV00_user_ low_ship_meta Click three dots on the right and select only "boot.img, recovery.img and system.img" PHONE: Blank CSC: CSC_OXM_G955FOXM1AQDG_CL11168760_QB13362118_REV00_ user_low_ship Click three dots on the right and select only "cache.img" 7. Flash the phone |
The Following 3 Users Say Thank You to Bertie*#06# For This Useful Post: |
11-14-2017, 20:08 | #201 (permalink) |
Crazy Poster Join Date: Nov 2016 Location: The Greatest fiji islands
Member: 2644395 Status: Offline Thanks Meter: 11 | Thanks its working like a charm on g955f if u follow instructions corectly it will not even take 2 minutes to reboot after flash thanks hosam u r the best |
11-16-2017, 14:50 | #203 (permalink) |
No Life Poster Join Date: Mar 2017 Location: Muhosransk
Member: 2698409 Status: Offline Thanks Meter: 244 | You can download working, not corrupted combination for G955N from here: https://filesrom.com/bypass-frp-unbr...ea-g950n-g955n |
11-26-2017, 11:37 | #209 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | I did this without z3x Quote:
I used MiracleBox?SAMSUNG TAB to flash the files But the TRICKY part is YOU MUST EXTRACT using 7zp to CREATE FLASH FILE system+sboot+boot+recovery+cache *************************************** MODIFIED TO BE: BL = sboot AP = Boot + recovery + system+meta file HOME CSC= cache Then follow the PROCESS explained above NO PROBLEM FOUND EASY and SIMPLE | |
