Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
07-20-2002, 05:29 | #1 (permalink) |
Insane Poster Join Date: Jul 2001 Location: Germany
Member: 5460 Status: Offline Thanks Meter: 0 | help to unlock Sagem MW 930 can anybody tell me how i can surely unlock it please? thanks for your help. Best Regard |
07-20-2002, 14:01 | #2 (permalink) |
Insane Poster Join Date: Nov 2001 Location: Moscow, Russia
Member: 7477 Status: Offline Thanks Meter: 0 | You can use 2 programs - mw_bootstrap_to (to fund phone id) and sagem doctor - (to change field 251 and recalculate checksums with value 00 for 251.) And data cable for 9xx phone. |
07-20-2002, 16:45 | #3 (permalink) |
Member: 5460 Status: Offline Thanks Meter: 0 | Hi and after i recalculate the checksums what should i do? i have read also somewhere that i can use the prog SGM_SSW to calculate the code and after that i insert a sim card that the phone doesnīt accept i must enter the 10 digit code that the has calculated and that all. But dindnīt success to enter all the 10 digit , the phone take only 8 digit , how can i enter all the 10 digit in the phone? Thanks for your help Best Regard |
07-20-2002, 16:57 | #5 (permalink) |
Member: 5460 Status: Offline Thanks Meter: 0 | but any time i enter the 8 digits the phone tell me wrong code and i have already use all the try and the phone shows me now "last try". you dindnīt tell me what i will do after i will recalculate the checksums with the Sagem doctor. please man help me thanks |
07-20-2002, 17:12 | #6 (permalink) |
Member: 7477 Status: Offline Thanks Meter: 0 | I'll try to explain more detal 1. Using sagem doctor we must make backup of eeprom 2. If all fields can be read - it's good 3. With mw_bootstrap_tool we can find the phone id. 4. If you have last attempt you must change eeprom field 231 to 00 with sagem doctor 5. If you phone says simlock only with sim card - it means checksums are correct (we will see this case) 6. If your phone shows simlock without simcard - checksums are bad. 7. Try to re-calculate checksums with doctor You have to enter phone id manually (which you get early) If all sums are correct goto p.8 If not - check if phone id and hash table for this version is correct 8. Change field 251 to any other value 9. Recalculate checksums and when it will say 251 - invalid - choose manual enter - and put 00 10. After finishing calculation restart the phone - swich it off and on It must be unlocked. |
help to unlock sagem MW 936 | hacker1gsm | Infineon C16X M51 & ARM7 M52 BASED | 0 | 02-07-2002 05:13 |
PLEASE HELP ME WITH SAGEM MW 930 | IceKiller ZLIN | Infineon C16X M51 & ARM7 M52 BASED | 2 | 02-04-2002 11:54 |
unlock Sagem MW 930 | ripper_bg | Infineon C16X M51 & ARM7 M52 BASED | 0 | 08-22-2001 21:18 |
How to unlock Sagem MW 3026? | HuyGSM | Infineon C16X M51 & ARM7 M52 BASED | 2 | 07-07-2001 09:51 |
How to unlock Sagem MW 3026? | HuyGSM | Infineon C16X M51 & ARM7 M52 BASED | 0 | 06-12-2001 15:21 |
