07-13-2005, 20:42 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: 9 JA
Member: 30405 Status: Offline Thanks Meter: 3 | Phone startup fail(6260) solution !! Initializing Phone... Flash configuration: 9B040001007E00160011010201007E00... Boot and Flash loaders operation took 9.514000 seconds Erasing - erase took 255.237012 seconds Flashing MCU Skipping bluetooth data - flashing took 413.204020 seconds Flash configuration: 9B040001007E00160011010201007E00... Erasing - erase took 16.184001 seconds Flashing PPM - flashing took 29.522001 seconds Flashing DONE After flash processing... Phone data: V RD_2004_wk24/15-07-04/RM-25/(c) Nokia. IMEI 353793008132246 Product Code 0517001 Set Factory Default Settings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . set FAIL No Java upload specified Write Product profile file: C:\Program Files\Nokia\Phoenix\Products\RH-37\china.pp Product Profile Accepted AfpOK I ve done this several times still getting phone startup fail contact retailer Am using griffin 2.0985 Any help will be appreciated All d best |
07-14-2005, 14:06 | #6 (permalink) | |
Registered User Join Date: Oct 2003 Location: Vietnam Age: 47
Member: 40808 Status: Offline Thanks Meter: 10 | Quote:
But if u really don't know where is flash ic then better don't try to play with it! regards | |
07-15-2005, 06:23 | #8 (permalink) |
Member: 40808 Status: Offline Thanks Meter: 10 | Hmm, let use search button and try to find out the Service manual, u will have what need! But i think in this case of u, try format user area first, almost phone startup fail pb can solved with SW, no need to HW repairs! Try format it, maybe it still fail at the first time, try again, if not done let flash it with China version then format again! regards |
03-12-2007, 07:53 | #12 (permalink) |
No Life Poster Join Date: May 2004 Location: Coimbatore, India Age: 41
Member: 65535 Status: Offline Thanks Meter: 451 | try to format ur user area in ufs otherwise erase ur ppm area with 6260 erase file after write full flash thn do user area format ur 90% solve if not slve mean that is 100% hardware problem |
flashing e51 on usb.phone flashing complete but show phone startup failed | ravin j tejura | Universalbox | 1 | 12-14-2009 14:43 |
credits lost and now phone is on phone startup failed | vikas chadha | Universalbox | 9 | 03-18-2009 12:29 |
Bb5 phone startup failed solution with hwk | KARABO | HWK | 8 | 01-15-2009 07:54 |
6260 any solution for repair: Phone Startup Filed. | IkaMazini | Nokia Hardware & Hardware Repair | 16 | 06-04-2007 07:56 |
Maxon O2X1 User Code Reset Solution & Startup Hang Solution !!! 100% | Aamir_Zia | Various | 43 | 01-14-2006 22:49 |
