Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 01-01-2005, 23:35   #1 (permalink)
Member: 40901
Thanks Meter: 2
Widcomm 4.0.1.700
The installation for the drivers can be downloaded here
http://www.mobidick.biz/downloads.shtml
and the Patched files are attached.
New profiles included:
* GAVDP -- Generic Audio Video Distribution Profile
* A2DP -- Advanced Audio Distribution Profile
* AVRCP -- Audio Video Remote Control Profile
Old 01-02-2005, 00:57   #2 (permalink)
Member: 102506
Thanks a lot Phantasm4489. It works well with the internal bluetooth on thinkpad t42.
In Local Services and Client Applications, it doesn't seem to have new entries for A2DP. There's still the old Audio Gateway and Headset. Is that normal? I was hoping to use the new stack with a stereo headphone.
Old 01-02-2005, 01:16   #3 (permalink)
Member: 40901
Thanks Meter: 2
I get the same thing, but I dont know what the requirements are for these extra profiles. I have no idea if they only work with bluetooth 1.2 or not.
Same with with the BIP (basic imaging profile) from the widcomm version 3.0, that also doesnt appear in the tray list.
Old 01-02-2005, 01:26   #4 (permalink)
Member: 102506
I do have "Bluetooth Imaging" in both Local Services and Client Applications in 4.0. Do you not have that?
My internal bluetooth is supposed to support bluetooth 1.2. I am afraid that A2DP needs additional hardware support, or this stack only has A2DP on Broadcom hardware ...
Anyway, my MX900 mouse works much better now in terms of mouse movement. I was using XP SP2 bluetooth stack.
Old 01-02-2005, 01:31   #5 (permalink)
Member: 40901
Thanks Meter: 2
Widcomm 4.0.1.700
Nope I dont even get Bluetooth Imaging.
Old 01-02-2005, 02:04   #6 (permalink)
Member: 102506
Oh I spoke too soon. The patched 4.0 fails to find a bluetooth device everytime I restart Windows XP (SP2). If I turn off the bluetooth radio and turn it back on, the 4.0 stack will recongnize it.
Old 01-02-2005, 16:58   #7 (permalink)
Member: 102677
I'M interested in the A2DP features for my Bluetake I-Phono stereo headphones too. I'd like to be able to listen to stereo recordings without using the dongle. Any luck, auvi?
My silly question is how do I incorporate the patched files into the Widcomm 4 update. Currently I have an old Widcomm (from jons guide) for my internal radio on a Sony Vaio S.
Old 01-02-2005, 19:19   #8 (permalink)
Member: 50296
One problem that i found with this version was that in games the mouse fails to fire continuously... The mouse isn't bluetooth... Probably something to do with driver hooks for bluetooth hid?
Old 01-02-2005, 19:41   #9 (permalink)
Yolly Zubrick's Avatar
Member: 8396
Thanks Meter: 2
Big thanks Phantasm4489. Great gift for the New Year. The v3.0.1.905 was quite stable for me, though I get that annoying "Error" everytime I connect to the serial port on XP SP2. I'd like to see if that get fixed in this version.
Hmm, I guess there's a typo in the thread title, which says v4.0.1.900 but it's actually v4.0.1.700. Somehow, I have this feeling the bigger numbers are better, so I hope this one performs better than v3.x.x.x Still crawling on 56K but GetRight will be done with this thing in about 2 hours time. Can't wait to test it.
Big thanks again dude
Old 01-02-2005, 19:52   #10 (permalink)
Starvirus's Avatar
Member: 41465
Sonork: 100.61907
Thanks Meter: 341
hi
good work, it works good with an csr dongle but it doesn't accept an bt hub from logitech e.g. for mx900, it install no driver for that. has anyone a idea why it doesn't accept that?
Starvirus2
Old 01-03-2005, 00:18   #11 (permalink)
Member: 40901
Thanks Meter: 2
Yep it was a typo, i did try to change it but it doesnt seem to make any difference
Old 01-03-2005, 02:57   #12 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
LİNK DEAD other link?
Old 01-03-2005, 12:33   #13 (permalink)
Member: 102528
Hey, I'm getting license.dat message - using Alps sony vaio internal BT module. I have followed your instructions on copy of four patched files. Any Ideas?
Thanks
Old 01-03-2005, 15:01   #14 (permalink)
Member: 8396
Thanks Meter: 2
Tested. And my personal verdict: 10/10 *****(5 stars) a must-have. The "Error" on Serial port COM connect I am having in v3.x.x.x is gone in this new version.
Tip: If you have version v3.x.x.x, you will actually have an "Upgrade" option if you run Setup.exe on top of an existing installation, might also be true with v1.x.x.x. So I gave it a try, and the upgrade process was quite smooth. Just boot to safe mode and do the patching and start enjoying v4.x.x.x on your next boot. It's really worth the time and effort (imagine 30MB on dial-up!! wheew! but no regrets )
Big thanks again to Phantasm4489
Old 01-03-2005, 20:31   #15 (permalink)
Member: 102528
license.dat problem
what software should I use to patch the files? Should the patched files provided do it or i need to do it again?
Thanks
[IMG] code is Off
Widcomm 4.0.1.2101 billyx Bluetooth-Software 174 11-05-2008 13:00
Widcomm 4.0.1.2800 Scar Bluetooth-Software 15 10-14-2007 11:03
Widcomm 4.0.1.2101 problem ][No_WaY Bluetooth-Software 4 08-20-2005 14:50
widcomm 4.0.1.2101 with older drivers ? MUSANI Bluetooth-Software 0 08-05-2005 02:09
Widcomm 4.0.1.1500 billyx Bluetooth-Software 16 06-30-2005 23:42
Page generated in 0.30219 seconds with 11 queries
