01-11-2006, 07:06 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Age: 44
Member: 10579 Status: Offline Thanks Meter: 0 | Stuck in DFU mode eve with the last widcomm 5 tells me no hardware found and i try to use dfu wizard but keep giveng me this dfu mode error :firmware upgrade mode could not be controlled and in hardware mang. under bluetooth section gives me: 1- bluetooth bus enumerator 2- dell trumoblie bluetooth module in firmware upgrade any help? |
01-11-2006, 16:43 | #3 (permalink) | |
Member: 10579 Status: Offline Thanks Meter: 0 | Quote:
01-11-2006, 23:47 | #6 (permalink) |
Junior Member Join Date: Jan 2006
Member: 216388 Status: Offline Thanks Meter: 0 | can you try turning it back to normal with the firmware upgrade program? At the very worst, you'll need to re-install Windows or do a repair install. http://www.michaelstevenstech.com/XPrepairinstall.htm |
01-13-2006, 12:27 | #9 (permalink) | |
Member: 216388 Status: Offline Thanks Meter: 0 | Quote:
http://66.249.93.104/search?q=cache:...dfu+mode&hl=en | |
03-28-2006, 23:49 | #10 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251666 Status: Offline Thanks Meter: 0 | same problem I'm trying to solve just the same situation - I found that there is a driver pack from Dell which includes firmware file (R77162 ...in svcpack directory), now I'm seeking for way to flash it in. Firmware flasher in appropriate trhread (http://forum.gsmhosting.com/vbb/showthread.php?t=166014) doesn't work... Last edited by maximal42; 03-29-2006 at 13:43. |
03-29-2006, 13:47 | #11 (permalink) |
Member: 251666 Status: Offline Thanks Meter: 0 | now what? I found the flasher and tried to upload Dell firmware using it - it shows different vendor error. Please advise working firmware for this BT, or how to disable vendor check (to be able to flash dell firmware by force). I tried the actual one in firmware upgrade thread, one included with flasher and none worked (0 of ... bytes loaded -> file verification failed) |
03-30-2006, 00:40 | #12 (permalink) |
Member: 251666 Status: Offline Thanks Meter: 0 | Complete Heureka I used firmware flasher from driver pack version A02 (after installation in \bluetooth software\bin\btdfuapp.exe) and firmware included in complete A05 version (R77162 ... svcpack directory). Easy as killing bunnies with axes. |
Iphone 3Gs in DFU mode , how can exit dfu mode ? | dieuphong2003 | iPhone 2 / iPhone 3G / iPhone 3GS | 37 | 06-23-2011 13:58 |
[HELP] - Stuck in DFU mode Black screen | jajukhan | iPhone 2 / iPhone 3G / iPhone 3GS | 31 | 10-28-2010 01:45 |
iPod touch 3.1.2 stuck in DFU mode HELP | beerfoote1 | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 03-19-2010 15:07 |
iphone 3gs stuck on dfu mode... | SicilianBoy | iPhone 2 / iPhone 3G / iPhone 3GS | 10 | 03-10-2010 12:06 |
Stuck in DFU mode. Upgrade failed | a27 | Bluetooth-Software | 2 | 01-04-2006 19:19 |
