Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 06-12-2015, 14:30   #1 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,670
Arrow LIC5: False REQ FBI Failed !
App: UFSx (HWK) Control Panel v 2.3.0.6 by SarasSoft
CPU: GenuineIntel
Platform: Windows NT 6.1 (Build 7601 Service Pack 1)
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
C:\Program Files
C:\Program Files\Common Files
C:\Program Files\Nokia\Phoenix\
C:\Users\Farhan Mobile\Desktop
C:\Users\Farhan Mobile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
Last Server Update: 2015/06/11
Active Panel Version: 2.3.0.6
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 49 Serial: 7xxxx
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn:xxxxx
BOX_AUTH_ERROR: 20
BOX: CORRUPTED or MANIPULATED
Bad IX: ABCD
Failed: -5
HID Number Corrupted, Try to Use [Update Box]
Box: 1 Location: 49 Serial: xxxxx
UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx
BOX_AUTH_ERROR: 20
Your IP: 223.176.63.245
Support: Bad HID, Cannot Access Support
-- Reset Failed, Trying to Repair UFS ...
-- Boot: 62 CF
-- Done, use [Update Box] to authorise UFS.
UFSx: UFS3 SarasSoft, USB S/N: xxxxx
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: xxxxx
LIC5: False
REQ FBI Failed !
The Following User Says Thank You to jawedakht For This Useful Post:
Old 09-22-2015, 13:07   #2 (permalink)
bilousoft's Avatar
Member: 204662
Thanks Meter: 91
Your IP: 197.117.95.237
-- Boot: 62 CF
NVML: Ok
SERN: xxxx
LIC5: False
REQ FBI Failed !
same problem here
Old 09-22-2015, 13:16   #3 (permalink)
Member: 2082450
Thanks Meter: 1,454
Solution here
Hello to all,
If u face this problem, Do the Following
1 Install the latest panel i.e 2.3.0.7 currently.
2 Use Original usb A-B cable.
3 Plug directly to the computer
4 Don't use any extension cord or usb hub.
5 Use High speed internet.
6 Disable antivirus/Firewall.
7 Update box
Definitely get success.
chandanps18
The Following 2 Users Say Thank You to chandanps18 For This Useful Post:
Old 09-22-2015, 17:04   #4 (permalink)
bilousoft's Avatar
Member: 204662
Thanks Meter: 91
Originally Posted by chandanps18 View Post
Hello to all,
7 Update box
chandanps18
SAME PROBLEM any idea
Old 09-24-2015, 18:11   #5 (permalink)
Member: 2082450
Thanks Meter: 1,454
Change the usb A-B Cable.
It is very urgent.
Post result..
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 09-29-2015, 18:53   #6 (permalink)
bilousoft's Avatar
Member: 204662
Thanks Meter: 91
It is very urgent.
Post result..
same problem sorry
Old 09-29-2015, 23:43   #7 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
Same Problem
Box: 1 Location: 305 Serial:
HWK Preset 1 Error: 00, 0
BOX_AUTH_ERROR: 52
Your IP: 217.15.117.104
-- Boot: 62 CF
NVML: Ok
SERN:
LIC5: False
REQ FBI Failed !
Different cables,different ISP with high high speed 10mb/s
Different computers ,no change
Firewalls Off,Antivirus off =Still same problem,day and night no change.
May be new panel needed.
Old 09-30-2015, 00:11   #8 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
Finally Updated my HWK
What I did:
1.Download this UFS_PANEL_2307 ( UFS_PANEL_2307 - Download - 4shared ) and extract it to your desktop
2.Disable Firewalls and Antivirus
3.Have a memory stick in your Hand
4.Check if your internet is currently running
5.Run UFS_PANEL_2307.exe
6.Scan Box-Check Box (if Your pc freezes a bit,disconnect box from cable and re-insert it) then Click UPDATE BOX
When you see Client sticking at 2% (or 0%), insert the memory stick in one of the box s usb port for 1 second and
remove memory stick.Update will star and you will get:
"Authentication successfull.
Upgrade client is up-to-date.
Upgrade process completed" :
message.Panel will freeze a bit insert the memory stick again for a second.
That s all.Box ready to be used after installing software.
The Following User Says Thank You to blaiseid For This Useful Post:
Old 10-01-2015, 10:28   #9 (permalink)
bilousoft's Avatar
Member: 204662
Thanks Meter: 91
What I did:
STILL NO SOLUTION DONT WORK FOR ME
Old 10-01-2015, 12:44   #10 (permalink)
Member: 2136362
Thanks Meter: 31
try in oither system.
if no solution get, ur box damaged.
time to buy new one..
The Following User Says Thank You to pintu mangaraj For This Useful Post:
Old 10-02-2015, 09:33   #11 (permalink)
bilousoft's Avatar
Member: 204662
Thanks Meter: 91
If no solution get, ur box damaged.
Time to buy new one..
after change system to xp and onther machine update ok and box ok thank you for support
br
bilousoft
Old 05-04-2016, 01:25   #12 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
bad cables....white cable with red ends not good for update, all through green cable ok
Old 07-22-2016, 12:13   #13 (permalink)
Member: 2219960
What I did:
Nice solution done after insert memory stick
Page generated in 0.21175 seconds with 8 queries
