06-12-2015, 14:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Jainagar Bihar
Member: 992600 Status: Offline Thanks Meter: 1,670 | LIC5: False REQ FBI Failed ! CPU: GenuineIntel Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files C:\Program Files\Nokia\Phoenix\ C:\Users\Farhan Mobile\Desktop C:\Users\Farhan Mobile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Last Server Update: 2015/06/11 Active Panel Version: 2.3.0.6 App: UFSx (HWK) Control Panel v 2.3.0.6 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 49 Serial: 7xxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn:xxxxx BOX_AUTH_ERROR: 20 BOX: CORRUPTED or MANIPULATED Bad IX: ABCD Failed: -5 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 49 Serial: xxxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx BOX_AUTH_ERROR: 20 BOX: CORRUPTED or MANIPULATED Your IP: 223.176.63.245 Support: Bad HID, Cannot Access Support -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use [Update Box] to authorise UFS. UFSx: UFS3 SarasSoft, USB S/N: xxxxx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: xxxxx LIC5: False REQ FBI Failed ! |
The Following User Says Thank You to jawedakht For This Useful Post: |
09-22-2015, 13:07 | #2 (permalink) |
No Life Poster Join Date: Dec 2005 Location: in my mind Age: 43
Member: 204662 Status: Offline Thanks Meter: 91 | BOX: CORRUPTED or MANIPULATED Your IP: 197.117.95.237 Support: Bad HID, Cannot Access Support -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use [Update Box] to authorise UFS. UFSx: UFS3 SarasSoft, USB S/N: xxxx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: xxxx LIC5: False REQ FBI Failed ! same problem here |
09-22-2015, 13:16 | #3 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Solution here Hello to all, If u face this problem, Do the Following 1 Install the latest panel i.e 2.3.0.7 currently. 2 Use Original usb A-B cable. 3 Plug directly to the computer 4 Don't use any extension cord or usb hub. 5 Use High speed internet. 6 Disable antivirus/Firewall. 7 Update box Definitely get success. Br chandanps18 |
The Following 2 Users Say Thank You to chandanps18 For This Useful Post: |
09-22-2015, 17:04 | #4 (permalink) | |
Member: 204662 Status: Offline Thanks Meter: 91 | Quote:
09-29-2015, 23:43 | #7 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Same Problem ------------------ Box: 1 Location: 305 Serial: UFxBoot V2.2 (c) SarasSoft 2003., Id: UFS_USB V2.8 (c) SarasSoft 2007., Sn: HWK Preset 1 Error: 00, 0 BOX_AUTH_ERROR: 52 BOX: CORRUPTED or MANIPULATED Your IP: 217.15.117.104 Support: Bad HID, Cannot Access Support -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use [Update Box] to authorise UFS. UFSx: UFS3 SarasSoft, USB S/N: NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: LIC5: False REQ FBI Failed ! ------------------ Different cables,different ISP with high high speed 10mb/s Different computers ,no change Firewalls Off,Antivirus off =Still same problem,day and night no change. May be new panel needed. |
09-30-2015, 00:11 | #8 (permalink) |
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Finally Updated my HWK ---------------------- What I did: 1.Download this UFS_PANEL_2307 ( UFS_PANEL_2307 - Download - 4shared ) and extract it to your desktop 2.Disable Firewalls and Antivirus 3.Have a memory stick in your Hand 4.Check if your internet is currently running 5.Run UFS_PANEL_2307.exe 6.Scan Box-Check Box (if Your pc freezes a bit,disconnect box from cable and re-insert it) then Click UPDATE BOX When you see Client sticking at 2% (or 0%), insert the memory stick in one of the box s usb port for 1 second and remove memory stick.Update will star and you will get: "Authentication successfull. Upgrade client is up-to-date. Upgrade process completed" : message.Panel will freeze a bit insert the memory stick again for a second. That s all.Box ready to be used after installing software. |
The Following User Says Thank You to blaiseid For This Useful Post: |
10-01-2015, 10:28 | #9 (permalink) | |
07-22-2016, 12:13 | #13 (permalink) | |
Junior Member Join Date: Jul 2014
Member: 2219960 Status: Offline Thanks Meter: 1 | Quote:
