07-12-2004, 16:33 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | Nokia 6600 - Phone Start-up Failed anybody can help me repari my Nokia 6600 ? I flashed it by a new UFS-3 but I got a error : " Phone Start-up Failed. Contact the retailer " I couldnt also format User area by UFS and by phone itself ( Green Key + * + Number 3 + power on ) need help |
07-12-2004, 22:44 | #6 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Pakistan Age: 42
Member: 56561 Status: Offline Sonork: 100.114006 Thanks Meter: 41 | TAHNKS TO SIR X-Shadow Simple Solution for 6600 "Contact Retailer" and 4Binks using Twister Software Step 1: Click ERASE Flash start address: 02000000 end address: 027FFFFF * if you get an "Erase Flash Error" message in a specific address in the flash ic, this means that you have a damaged flash IC. You will need to replace flash IC number 2 inside the phone. (The 6600 has 4 flash ICs inside). Step 2: If you are successfull in erasing flash IC number 2, make a full flash of the phone... MCU + PPM + Bluetooth if necessary. Step 3. If you are successfull in full flashing the phone, put battery inside phone and you SHOULD GET "Contact Retailer" message again. Now remove the battery, put it back and hold buttons "call(green button on the left)" + "*" + "3" then press the power button while still holding the 3 buttons above... The phone should start formating itself (note that there must be no sim card inside the phone while doing this...) After formatting, phone should be ok... but need to update a good PM file if necessary. TAHNKS TO SIR X-Shadow WBR Imran Khatri |
07-26-2004, 08:14 | #7 (permalink) |
No Life Poster Join Date: Apr 2004 Location: india Age: 47
Member: 62016 Status: Offline Thanks Meter: 48 | this is the full setup for Nokia 6600 - Phone Start-up Failed 1) flash the phone with c3 files v4.32 go and download from www.gsmhall.com 2) the mobile will ok but mobile will ok unlock it and format it 3) flash the phone with mcu and ppm with the v4.32 only 4) now unlock it and format |
Nokia 6600 "Phone start-up failed. Contact the Retailer" | GMX@cool | WD2 & APE (Symbian Phones) | 73 | 04-24-2013 12:00 |
6600 phone start up failed contact retailer | danish_teli | Nokia Hardware & Hardware Repair | 32 | 08-31-2012 15:23 |
6600 phone start-up failed.! | Harisk | WD2 & APE (Symbian Phones) | 6 | 11-29-2008 19:37 |
6600 phone start up failed contect the retailer | bharatg | Nokia Hardware & Hardware Repair | 20 | 04-01-2008 11:19 |
6600 phone start up failed? | gpong | Nokia Hardware & Hardware Repair | 5 | 11-30-2006 03:47 |
