WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
05-24-2004, 12:12 | #4 (permalink) | |
Freak Poster Join Date: Jan 2003
Member: 19429 Status: Offline Thanks Meter: 15 | @ Quote:
NOT WORK!!! FORMATING Stoped 3%-5% | |
05-25-2004, 04:34 | #5 (permalink) | |
No Life Poster Join Date: May 2004 Location: Bandung-Flasher.com
Member: 65947 Status: Offline Thanks Meter: 135 | Quote:
ragards. | |
05-26-2004, 08:04 | #6 (permalink) |
Insane Poster Join Date: Feb 2004 Location: indonesia (north sulawesi) Age: 45
Member: 51653 Status: Offline Thanks Meter: 1 | @GMX@cool [THK!!! NOT WORK!!! FORMATING Stoped 3%-5%] sorry... i forget to tell u... u have to use foll batteray.... pls try again.... i have the same problem...but it work 100% |
05-26-2004, 08:05 | #7 (permalink) |
Member: 51653 Status: Offline Thanks Meter: 1 | @GMX@cool [THK!!! NOT WORK!!! FORMATING Stoped 3%-5%] sorry... i forget to tell u... u have to use full batteray or use new.... pls try again.... i have the same problem...but it work 100% |
05-26-2004, 13:30 | #8 (permalink) |
Major Poster Join Date: Feb 2004 Age: 47
Member: 51636 Status: Offline Thanks Meter: 1 | If you u using griffin as you flasher tool, then this is the solution: 1)Backup ur phone PM files. (if you already have PM file then skip this) 2)Flash your phone with erase file. (for 3650/3660 is "3650_erase_flash0_flash1_flash2.fia") (for 6600 is "6600_fullerase.fia") 3)Flash your phone with phone firmware. (file end with extension C1, C2, C4, C5.....) 4)Flash your phone with PPM firmware.(for those english firmware version, ppm is compulsary else you get 4X blink, PPM file end with extension 01,02,03,04....) (chinese combo no ppm firmware so skip this) 5)Upload PM file that is just backup. 6)Upload SIM Rebuild to enable sim card. DONE. Your phone is working again. |
07-12-2004, 16:27 | #10 (permalink) |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | hi I flashed 6600 by ufs-3 and I got a error: " Phone start-up failed. please contact the retailer " anybody has any idea ? I couldnt format User area . when I try to read UEM info, its serial. it shows me ????--??? , what should i do ? i really need help ???????/ |
07-12-2004, 22:54 | #11 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Pakistan Age: 42
Member: 56561 Status: Offline Sonork: 100.114006 Thanks Meter: 41 | Simple Solution for 6600 "Contact Retailer" and 4Binks using Twister, UFS Software Step 1: Click ERASE Flash start address: 02000000 end address: 027FFFFF * if you get an "Erase Flash Error" message in a specific address in the flash ic, this means that you have a damaged flash IC. You will need to replace flash IC number 2 inside the phone. (The 6600 has 4 flash ICs inside). Step 2: If you are successfull in erasing flash IC number 2, make a full flash of the phone... MCU + PPM + Bluetooth if necessary. Step 3. If you are successfull in full flashing the phone, put battery inside phone and you SHOULD GET "Contact Retailer" message again. Now remove the battery, put it back and hold buttons "call(green button on the left)" + "*" + "3" then press the power button while still holding the 3 buttons above... The phone should start formating itself (note that there must be no sim card inside the phone while doing this...) After formatting, phone should be ok... but need to update a good PM file if necessary. TAHNKS TO SIR X-Shadow WBR Imran Khatri |
07-28-2004, 16:44 | #13 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Czech republic Age: 51
Member: 22991 Status: Offline Thanks Meter: 0 | Thank you, work fine. If you have not backup of Important PM values, you can use also downloading from the other phone, but after uploading PM you must also upload SIM Rebuild information from the same phone like PM values. Now tested by me and 100% working. |
07-28-2004, 17:32 | #14 (permalink) |
Freak Poster Join Date: Sep 2003 Location: nigeria Age: 46
Member: 38959 Status: Offline Thanks Meter: 0 | hi guyz i flashed phone and formated user area, but now i get a strange problem. When i power the phone it says 'App. closed Main' and when i press ok the phone boots up alright but powers down after 15secs and reboots again. can anyone help. |
Nokia 6670 "Phone start-up failed. Contact the Retailer" | nathanlei888 | Twisterflasher | 10 | 04-26-2011 13:13 |
Nokia N95 error "Phone start-up failed. Contact the retailer" | fagamon | Cyclonebox | 47 | 05-24-2009 05:24 |
6600 "Phone start-up failed. Contact the retailer" 3 seconds , "Insert sim" ... | bedspencer | Nokia Hardware & Hardware Repair | 3 | 11-29-2007 03:51 |
6600 "Phone start-up failed. Contact the retailer" 3 seconds , "Insert sim" ... | bedspencer | Nokia Hardware & Hardware Repair | 1 | 11-28-2007 10:14 |
6600 "Phone start-up failed. Contact the retailer" 3 seconds , "Insert sim" ... | bedspencer | Nokia Hardware & Hardware Repair | 0 | 11-28-2007 09:50 |
