Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 12-07-2004, 17:49   #136 (permalink)
Member: 32182
Thanks Meter: 2
My UFS-3 Box can not detect C200 Acer . I've tried on many pcs of C200 n C201
when I press infor it says "can not detect mobile brand pls. select manual"
the other models of Acer working well With my UFS-3 Box
while my friends's Twister box is doing well on C200 .
So, can u help to solve this Problm. ???
thanx.
Wbr.!
Old 12-08-2004, 14:35   #137 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
thanx.
Wbr.!
Did you tried to open the case as User Manual said ???
WBR
Old 12-08-2004, 16:04   #138 (permalink)
Member: 32182
Thanks Meter: 2
yes Sure !
I remove the front cover always n deeply press the Jack in
nothing has changed
Old 12-09-2004, 03:32   #139 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
hello there...
i have some words to say
first of all thanks for all of the saras team for such a wounderfull tool...
i have noticed some things, i dont know if u can call them bugs or what, there were browsing files problem (1.3e), when you open browse window for choosing files like MCU, PPM or CNT you can not arrange files by size so u can choose easly, support area is very poor (http://www.ufsx.com) always sreaching for flash files somwhere else cause i can not find them on the support area.
`till now there is no detailed user manual to explane the most used functions of the tool.
there are no discriptions for flash files which is on the support area like in SE area (languages).
in short words (support area need lots of work).
motorola software can not unlock C200 i tried lots of times (more than 20 difirrent phones), is there any intention to add (motorola E365)?
any plans for adding logging service for reparing bad IMEIs ?
user information phonebook reading it does not work all the time, sometimes it reads less names than which is on the phon`s memory.
i hope if u can put samsung arabic flash files in one folder, like in chinese flash files.
thanks in advance for future support , keep up the good work
Mansi
Old 12-09-2004, 03:49   #140 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
Originally Posted by singapore
I bought new ufs3 recently the flash files of dct3 goes directly to wintesla but the problem i am facing is that dct4 files when opened they dont go to phoenix application,even thought phoenix is installed the following error is showing;
the phoenix application cannot be found on the pc it is strongly recommended that phoenixis installed before this data pacakage do u wish to proceed with this is installation anyway y/no if we say yes the file is loaded in phoenix folder but when we flash dct4 phone the following error pop up
cannot open file c:\programmefile\nokia\phoenix\flash the system cannot find the file specified
when contact to the vendor he told to upload old version but the problem remain same tied this procedure in 3 computer but the problem is same ,even i formatted the c drive and freshly installed the ufs3 but with no positive results. what is wrong the software or the procedure of installation pl
help me
hello there...
to solve this problem do the following
1- install dctx1.3e on your hard drive it will be on (c:\programfiles\nokia\phonix\dctx1.3e)
2-install flash files needed to c:\programmefile\nokia\phoenix\
when message appears "the phoenix application cannot be found on the pc it is strongly recommended that phoenixis installed before this data pacakage do u wish to proceed with this is installation anyway y/no " choose yes.
3-install "flash update 3.13"
after connecting and flashing if the same message "cannot open file c:\programmefile\nokia\phoenix\flash the system cannot find the file specified" still appears reinstall dctx1.3e (overwrite all).
problem will be solved i hope [program need flash loaders which is inside (c:\programmefile\nokia\phoenix\flash )]
always install programe on your active partition
when using 2 Oprating systems like win98 and winxp you need to install dctx on c drive when using 98 and on d rive when using xp.
Mansi
Old 12-09-2004, 03:55   #141 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
sorry one last bug...
when flashing 7650 choosed mcu+ppm after finishing mcu program stops and say proccess failed and ppm area is empty had to reflash ppm using (flash ppm only) option.
thank you
Mansi
Old 12-09-2004, 15:48   #142 (permalink)
skorn's Avatar
Member: 95940
big problem with samsung
if is someone up there please help....
I have a ufs3 flasher that works super fine exept wirh samsung phones
can't detect phone and I tried with s300m, e715, x600, a800 and always the same problem:
1) when i try to get info, unlock, reset MMi i get: "failed to enter test mode"
2)when try to read or write flash i get :"1st boot failed: 1st response"
what is happening? the phone is restarted if i give the "restart" comand, and when i tri to read or write flash is shuting down
i'v used softare versions 14i,h,k,l,m same problem every time
tried to boot phones at all baud rates.
i don't now what to do
Please help
thanx in advance
Old 12-09-2004, 17:30   #143 (permalink)
SJS
SJS's Avatar
Member: 14684
Thanks Meter: 60
You must connect without battery!
Or cable is not good!
Old 12-14-2004, 07:57   #144 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
yes Sure !
nothing has changed
1st connect software. Connect cable to OFF phone {better u open its casings} & BOX.
Now TURN ON the phone.
Here comes the TRICK - push Read INFO - and then push power on button of PHONE twice thrice a little bit. It will surely read the INFO. Then do your desired task.
ONE more thing - sometimes you will have to adjust the cable position inside the phone JACK. Watch for the BLUE led status of BOX. Place cable in such a way that BLUE led shows some activity.
It is all about adjusting and placing cable. Nothing more. UFS works fantastic. Twister as well.
Old 12-14-2004, 09:14   #145 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 136
sometimes, when i flah dtc3 phones, I select the mcu and pmm same version, it appears to flash it,( the blue line goes on when it writes te mcu flash too) but it flashes only PMM. I did not activate the flash pmm only. I had this problem with 3310., 5110, 3410, and 6210...
than I have to downgrade to 1.3 b or c to make it work...
Old 12-15-2004, 11:40   #146 (permalink)
Member: 82866
When im flashing SGH T100 in the middle of flashing become error...... then when i flash it again error cames???????
MCU File: T10ADVE2.axf CheckSum: C4E983CF
OGM File: T10AD VE2.ogm CheckSum: 7197BC50
Mobile Boot Failed
how do i flash if the phone is dead????? do i need to power on?????? pls tell i need it urgent??????
Old 12-15-2004, 14:15   #147 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
Thanks Meter: 87
hi members i have a 1260 nokia when i flash it with ufs it show contect service , i have try many time but same plz tell me how to flash nokia 1260 with ufs , in detail plz
regards
gondal
Old 12-25-2004, 07:40   #148 (permalink)
Member: 71019
Thanks Meter: 2
hi!
press mobile info ok.
but it not read flash.
help me
Old 12-25-2004, 07:45   #149 (permalink)
Member: 71019
Thanks Meter: 2
Read (write) flash ok.
step1: connect software
step2: click read flash and press power on==> ok
Old 12-25-2004, 09:11   #150 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
Originally Posted by melakamobile
ufs3 cannot unlock 2300a RM-5 ! griffin can successful to unlock this model ! This is the bugs .
Wrong, next time i will send you a screen s, unlocked easily.
Salam
Post here all successfuly flashed, unlocked and repaired phones with ATF software. dr_aybyd Advance-Box 6048 02-04-2019 16:48
Post here all Nokia 1200,1208,1209 and 1650 Network problems mobilecitycbk Nokia Hardware & Hardware Repair 12 09-20-2015 04:01
Post here all UFS 3 Tornado Box Tutorilas and videos?? nofear99 Nokia Base Band 5 ( BB-5 ) 2 01-24-2015 06:12
all members can post here all moto L7.L6.V3 and more of problem and also post solutio 786sunny Motorola Hardware Repair 3 04-12-2007 17:53
Page generated in 0.27845 seconds with 11 queries
