01-17-2005, 21:30 | #182 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Quote:
I had same problem... Try to enter code manual. put blocked sim inside and enter the codes. But this doesn't solve the problem why UFS3 doesn't do it's job... Regards | |
01-18-2005, 15:48 | #183 (permalink) |
Freak Poster Join Date: May 2003 Location: Moldova Age: 49
Member: 28713 Status: Offline Thanks Meter: 3 | Samsung c200 flashing problem I have problem with samsung C200. If i write flash always: Region: 1, 0x00000000-0x00000677, Length: 1656 bytes Region: 2, 0x00004000-0x00006C3B, Length: 11324 bytes Region: 3, 0x00020000-0x00020003, Length: 4 bytes Region: 4, 0x00040000-0x00A4B78F, Length: 10532752 bytes 1st Boot Ok, McuId: 000603EC, Rom: 00004B43, 5-1.0 2nd Boot Ok, McuId: 000603EC, Rom: 00004B43, 2-1.1 Fll Boot Ok, Vers: 5.11, fl_sceptre3_sgh_hw5_v24_C200.sre Flash1: Fl_Id: 00040000_227E1111 - Flash1: Unknown Metrics Flash2: Fl_Id: 00040000_227E2222 - Flash2: Unknown Metrics Baud Rate Set: 921600 bps Open: xV4?6e. Bad response: 0x0000, 0000 Write Failed at: 0x00000678 |
01-18-2005, 18:03 | #184 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 47
Member: 107602 Status: Offline Thanks Meter: 2 | need help hi friends I have bought a second hand UFS 2 now i need to upgrade it to UFS 3, as its a second hand i dont know the reseller. CAN ANY ONE HELP ME PLEASE??? my mail : [email protected] |
01-19-2005, 18:00 | #185 (permalink) |
No Life Poster Join Date: May 2002 Location: Portugal.dll
Member: 11915 Status: Offline Thanks Meter: 10 | Box not found Hello Mates, I have here one real problem with new UFS-3 , drivers installed , panel control OK , running box with Samsung sw and SE sw all ok , box detected, serial number detected ''True License'' , all ok . . . But when run NOKIA sw , i have error in communication with box , and sw not recognize serial number . . . Working under W98SE !!! Can i get help here ??? someone with same problem ? Regards, DaysGSM www.DaysGSM.com |
01-21-2005, 17:35 | #186 (permalink) |
Insane Poster Join Date: May 2003 Location: Latvia, Riga Age: 41
Member: 28936 Status: Offline Thanks Meter: 0 | I got 4 locks cloased after init locks on SE T230 Used 26h version. Thanks *** i have terminator. Log 21.01.2005. 18:22:44, Boot Time: 0:46 Firmware: T230, R4A014 prgCXC1122646_EMEA_1 BackUp: T230_354542005660754_21_01_2005__18_22_44.sim ------------------------ IMEI: 354542-00-566075-4 NCK : 82110220 NSCK: 70985399 CCK : 80152156 SPCK: 59993314 USER: Factory_Off : 0000 Sim_Locks Open, Mcc+Mnc: FFF-FF, 5555 55 |
01-22-2005, 00:37 | #187 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Yep, i encounter same problem. so i developed this theory: buy tornado-> best and complet tool on the market, and after buy for backup: terminator for SE (for 4 locks), griffin for nokia( bad flash), UFS for samsung (sometimes flash or unlock not work oki), and Martech for Siemens (there is no need to comment here) |
01-27-2005, 02:38 | #188 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 44
Member: 86649 Status: Offline Thanks Meter: 0 | Nokia 6820b (RH-26) support? why is the RH-26 not supported in UFS-3? will it be supported? ive tried using NHL-9 6820a and i get this message: Licence: True Init Test Mode Failed IMEI: ---, ASIC: please help. AIM - rps13sh |
01-27-2005, 12:41 | #189 (permalink) |
Insane Poster Join Date: Oct 2003 Location: East Africa,Tanzania,Mwanza Age: 55
Member: 40578 Status: Offline Thanks Meter: 0 | Hi, My ufs not working for nokia 2300 & 1100 sometimes flashing full but no rebooting mobile. Ui setting not working please help. And when I try flashing againg it brings error 1st boot dct 3 . then 2nd boot dct4 ok then error 1st Boot Err: Bad Resp DCT3 Cannot Detect Mobile Brand 1st Boot Err: Bad Resp UPP, 03 00 00 72 Process Failed, Repowering Mobile then does not power on I kill 4 phones please help. The problem increse when I down load dctx 1.3h |
01-28-2005, 06:47 | #190 (permalink) |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | Uncheck Autodetect Uncheck Use Ini.... Then Try to clean up the cable ends [Rj45 jack]. Check your USB port. Clean up the connecting cable jacks. Then try erase flash FIRST. Tick Full Factory & Init Simlocks. Then START Flashing the phone with desired MCU + PPM files. If needed write PM & again init simlock. Hope u can reach the final solution. |
01-30-2005, 08:03 | #193 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 65863 Status: Offline Thanks Meter: 15 | Hi Friends i think we need self test for nokia same like griffin and some phone info like product code info & BT adress i need to write pm for network parameter not to corrupt my imei B.R |
Post here all successfuly flashed, unlocked and repaired phones with ATF software. | dr_aybyd | Advance-Box | 6048 | 02-04-2019 16:48 |
Post here all Nokia 1200,1208,1209 and 1650 Network problems | mobilecitycbk | Nokia Hardware & Hardware Repair | 12 | 09-20-2015 04:01 |
Post here all UFS 3 Tornado Box Tutorilas and videos?? | nofear99 | Nokia Base Band 5 ( BB-5 ) | 2 | 01-24-2015 06:12 |
all members can post here all moto L7.L6.V3 and more of problem and also post solutio | 786sunny | Motorola Hardware Repair | 3 | 04-12-2007 17:53 |
