09-30-2005, 15:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 74084 Status: Offline Thanks Meter: 8 | 1100 Only light on Display! Help pls! I've an 1100 (rh18) with problem on display! There are only ligths! I've try to flash it with Twister and JAF too, without results! I've flash my 1100 (Erase+Mcu+PPM+ Write PM+ Init Simlock + Full factory defaults)with version 5.60 but nothing! Any solutions pls! What I can do? Thanks in advance! Bye |
09-30-2005, 15:56 | #2 (permalink) | |
Member: 75040 Status: Offline Thanks Meter: 11 | Quote:
maybe that can help u wbr Fallen Angel | |
09-30-2005, 17:40 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: malaysia Age: 40
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | Quote:
hello BR 1st do erase file 2 time ,than try flash it........after flash look at the fon LCD see got came out (local mode) o not..... if got try write PM file and run uisetting (ini simlock) and (reset userlock) just that two ..... than DONE. | |
09-30-2005, 18:23 | #5 (permalink) | |
Member: 74084 Status: Offline Thanks Meter: 8 | Quote:
Hi, I've try your procedure, but nothing! Any idea? | |
09-30-2005, 20:12 | #6 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Kepler22 Age: 46
Member: 93787 Status: Offline Sonork: 1646397 Thanks Meter: 9 | put a pin control disabled simcard in this phone and turn it on.after this,make a call to that simcard.you can see if the phone is working or not by this way.if the phone is working but there is nothing on display,then disassemble the phone lcd and clean the connector.try the phone with a different lcd...i mean you have many ways to find the damaged part.good luck. |
10-28-2005, 09:57 | #7 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Sogod So. Leyte Age: 47
Member: 139066 Status: Offline Thanks Meter: 6 | bro's, i still got the same problem with my 1100.., and the history of the phone was water damaged. i've checked for broken lines and found nothing coz some other lines are directed to UEM. is there any testpoints you knew? PLsssss help. |
10-29-2005, 16:59 | #8 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Hi Mate, If The Init Locks And Other Ui Settings Done So Thats Mean Its Not Software Problem So Plz Check Your Lcd Or Lcd Ways Thats The Thing I Have Tested Ok...................tested.ok Br Muneeb Akhtar Raza |
Let There B Light, And There Was, So Pls Give Me Light On My 8800 Pls, | macsonugoh | Nokia Hardware & Hardware Repair | 1 | 07-07-2008 15:16 |
1100 2.8v on display connector on board | linekbp | Nokia Hardware & Hardware Repair | 4 | 01-23-2008 11:27 |
ST60 no lights on display (hang-up) plz.help... | FMC_GSM | Infinity-Box | 2 | 07-23-2007 12:24 |
Nokia 1100 Flash Light On Help | bonnyk1 | Nokia Hardware & Hardware Repair | 1 | 09-21-2006 11:43 |
