09-12-2006, 14:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Portugal Age: 51
Member: 90668 Status: Offline Thanks Meter: 57 | Twister RTP doesn't work ! I have a Twister dongle and I never could get the RTP program to work. I've tried several times with T610 and T630 and could never unlock or flash one. I connect the dongle, next I select the phone model, then I press GO and connect the cable to the disconnected phone, sometimes the progress bar simply goes to 1%, other times it detects MCU_ID, but it never goes beyond that. If I'm doing anything wrong please correct my proceedings. Thanks in advance. Best Regards |
09-13-2006, 11:46 | #3 (permalink) |
Member: 90668 Status: Offline Thanks Meter: 57 | Hy, Thanks for your suggestion but, i?m not that new to this business. The first thing I did was clean the contacts, the second thing I did was try on several phones (let's say about 30), the third thing I did was buy another cable (about 4), and the fourth thing I did was try it in another computer! Nothing changed! What am I doing wrong? I've tryed with original software, HWK cracked software, HWK original software... WHAT AM I DOING WRONG? |
09-13-2006, 12:19 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
TO flash or Unlock any T610 & T630 in other words any RSA protected SE model, you shld remember 3 basic things 1) REMOVE RSA PROTECTION FIRST. 2) BETTERY SHOULD BE FULLY CHARGE. 3) TO FLASH FONE U MUST DO INIT LOCKS. Now how to remove RSA 1) Remove Bettery from phone just connect cable and then click RSA button not on GO button. 2) Now insert the Bettery and then RTP will start reading MCU_ID. 3) If it stop on 1% , 2% or on any % just remove and reattach bettery. 4) after that it will ask u for a MCU file just load the same MCU or any other MCU. a) if u use same MCU as in Fone then no need to flash it again. b) if u flash with other MCU then after init locks and init Sec. blk u need to flash your fone with same select mcu once again. otherwise it won't power on. 5) Now everything is OOK , Do Init Locks then Do Init SecBlk. hope this will help u , i also attached a document for your further reference. just download and read it carefully. Take Care ENJOY | |
11-22-2006, 12:34 | #5 (permalink) | |
Insane Poster Join Date: Dec 2005 Location: Austria
Member: 213935 Status: Offline Thanks Meter: 2 | Quote:
please , i need help, my phone refuse to switch on after trying to unlock it with twister RTP, what shall i do now ? please any suggestion how to solve this probleme? | |
MT-box doesn't work. Doesn't power on the phone. | James_S | MT-BOX | 23 | 04-14-2009 13:14 |
invalid filename error on twister rtp | SIXTUS | Twisterflasher | 0 | 03-18-2005 19:49 |
Question 2 Raskal about SE TOOL by the_laser and Twister RTP | levsha | Twisterflasher | 2 | 02-04-2005 09:33 |
Help !!! Twister soft doesn't start anymore on my windows XP | bonanza | Twisterflasher | 6 | 01-08-2005 11:19 |
Problem with Twister RTP 1.16 | dreamteam | Twisterflasher | 3 | 03-19-2004 21:55 |
