Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 12-01-2005, 19:20   #1 (permalink)
Member: 105625
Thanks Meter: 44
MT-box cables are broke. Can't read/write - only change modes.
I just installed my new MT-box, but it doesn't work. Application starts fine and box info is read, but when i connect a phone nothing happens. It does not power on in test mode, and application just says "Phone is in: Phone is not responding, power on phone!".
I have tried powering on manually, but nothing happens. I have also tried connecting charger to the box.
The phone works fine when used with twister. What is wrong?
Old 12-01-2005, 19:57   #2 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Connect cable convertor to box , and phone cable to convertor.
Old 12-01-2005, 20:12   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Yes,, its happen to me too, when i firstly use MT box..
I tought the cable was the same with any other RJ-45. But its not.
Just do what SoftMobile said: Connect cable convertor to box , and phone cable to convertor.
Old 12-01-2005, 20:29   #4 (permalink)
Member: 105625
Thanks Meter: 44
Ah... thanks.. So the converter is needed on all cables? Why isn't that one built in the box?
(i'm using the supplied cables)
Old 12-01-2005, 21:02   #5 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
All Nokia cables has 8 pin connector to box side, and need to use converter to connect it to box.
SE, LG 3G, Sharp 3G and C62 cable has 10 pin connector to box side and need to be connected directly to box (without converter)
Why this?
To enable you use old cables from Griffin, UFS etc
SE, LG 3G, Sharp 3G and C62 cables can be used only on MT and GTI box
Old 12-01-2005, 23:00   #6 (permalink)
Member: 105625
Thanks Meter: 44
It's still not working correctly... The phone powers on (in test/local mode) but application still says "Phone is in: Phone is not responding, power on phone!". I have managed to get the phone readed a few times, but it's not working like it should
Same problem on 3510i, 6610i, 3650.
Old 12-01-2005, 23:25   #7 (permalink)
Member deceased !!
andro's Avatar
Member: 10248
Thanks Meter: 25
HI
Can you check your cables is fit ok to phones
post some log pls
BR GT
The Following User Says Thank You to andro For This Useful Post:
Old 12-02-2005, 00:57   #8 (permalink)
Member: 105625
Thanks Meter: 44
Originally Posted by andro
HI
post some log pls
BR GT
I have done some testing with Twister cables now... All three phones connected good now, except a bug in software when reading info from 3650:Read ok, until "PM Version .....". Application freezes and needs to be closed via taskmanager. It's not possible to start MT-NK again before i reconnect usb cable.
The MT-box supplied cables are really poor quality!!! 3 of 3 i have tried so far has been unusable!!! Twister cables worked fine...
Old 12-02-2005, 08:43   #9 (permalink)
Member deceased !!
andro's Avatar
Member: 10248
Thanks Meter: 25
HI
You have this problem only on WD2 3650 phone ?
problem whit 3510i and 6610i is solved ?
WD2 phones have problems whit serial comunication even whit phoenix.
You must wait for soft time out for phone info after this you can flash phone.
Us version 1.12 pls
BR GT
Old 12-02-2005, 08:45   #10 (permalink)
Member: 201903
your cabel is wrong
today i test mt box whit 3510 and 3510i work perfekt
flash unlock read write pm no problem
Old 12-02-2005, 08:49   #11 (permalink)
Member: 201903
after atach your phone to kable power on manual
phone set to locall mod now read info and other
Old 12-02-2005, 15:59   #12 (permalink)
Member: 105625
Thanks Meter: 44
HI
Us version 1.12 pls
BR GT
It's only crashing when reading phone info from 3650. Haven't tested flashing. I let it stay for over 10 minutes, but it was still freezing...
Anyway, i just tested another phone, 3220, and the cables supplied with MT-box are simply broke. I have tested 3220, 3510i, 3650 and 7210 and none of them works. Phone starts in Local mode (i can even change mode), but application can't read them. The only cables i got working (of the ones i have tested so far) is 6660 and N-Gage cables.
Twister cables works fine...
I have 10PCS of MT-box for resale, and i don't know what to do right now... i can't sell them if the cables are broke
And i'm not sure i can open or test them either, cause then they are "used".
Old 12-02-2005, 16:01   #13 (permalink)
harryzz's Avatar
Member: 9216
Thanks Meter: 21
Anyway, i just tested another phone, 3220 and the cables supplied with MT-box are simply broke. I have tested 3220, 3510i, 3650 and 7210 and none of them works. 6660 and N-Gage worked OK though.
Hi
do not connect box to external hub or
connect to other usb on your computer.
br
harry
Old 12-03-2005, 06:46   #14 (permalink)
Member: 105625
Thanks Meter: 44
I have tried several USB-ports, and my hubs are powered externally - working fine with all other devices (twister/martech/etc)
Old 12-03-2005, 13:17   #15 (permalink)
harryzz's Avatar
Member: 9216
Thanks Meter: 21
Hi
just do not use external hubs doesnt matter is powered externaly or not.
br
harry
If box can't power on the phone it's porblem ?? utuh CPF-BOX Ⅱ 1 04-07-2009 06:08
u880 press power on the phone auto on n off chris2007 FuriousGold 4 10-03-2007 14:01
MT-box not work not power phone (vpp) Nowomiejska6 MT-BOX 7 05-19-2007 03:09
E310 keypad doesn't work after power on! nishaon NSPRO 1 02-05-2007 14:57
MT-box no power on the phone alexino MT-BOX 1 05-14-2006 19:11
Page generated in 0.24826 seconds with 9 queries
