Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-16-2008, 10:04   #1 (permalink)
Member: 524556
Thanks Meter: 3
e250 no ring,no sound
hi there i hav e250 with water damage ,i cleand it but now no ringer working no sound wat i do?
The Following User Says Thank You to baba_ji For This Useful Post:
Old 10-16-2008, 10:10   #2 (permalink)
Member: 306786
Sonork: 100.1596805
Thanks Meter: 516
check the buzzer and flex ribbon then if possible to replace it just try...
Old 10-16-2008, 16:21   #3 (permalink)
Member: 524556
Thanks Meter: 3
ringer is ok,and ringer amd speaker is the same?and if positive point break up from the pcb where i can jumper it plz help by pic
Old 10-16-2008, 17:14   #4 (permalink)
Member: 389002
Thanks Meter: 82
flash with e250d flashfile,,,100% ok
Old 10-16-2008, 17:36   #5 (permalink)
Member: 418015
Thanks Meter: 4
possibly the problem is in the flat cable
Old 10-16-2008, 17:50   #6 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
flex ribbon or flash it with e250d ( *#1234# )
The Following User Says Thank You to MMDEBILI For This Useful Post:
Old 10-17-2008, 11:17   #7 (permalink)
Member: 679863
Thanks Meter: 24
Broth . Try to change flex cable .happen to me ; now working well. Good luck.
Old 10-17-2008, 11:44   #8 (permalink)
Member: 820919
I have same problem. I change flex,buzer, and complet displey with table but no results. Now I flash with repair mode and will see...
Old 10-17-2008, 14:14   #9 (permalink)
Member: 524556
Thanks Meter: 3
where is the flex cable ,is the cable that connect the lcd with pcb or any other1?
Old 10-17-2008, 21:05   #10 (permalink)
Member: 679863
Thanks Meter: 24
Yes that one. Try to use an originale one and post rusolt.
Old 11-25-2008, 08:06   #11 (permalink)
Member: 660358
Sonork: 1585668
Thanks Meter: 13
hello
make jumper tow mintis backup battery after flash
Old 11-25-2008, 13:48   #12 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Check this way bro
By Shantobhai at 2008-11-25
The Following 8 Users Say Thank You to Shantobhai For This Useful Post:
Old 05-22-2009, 13:03   #13 (permalink)
Crazy Poster
Member: 944745
Thanks Meter: 10
Old 05-22-2009, 13:11   #14 (permalink)
Member: 607045
Thanks Meter: 127
try to fix this problem by write erom.
Old 05-24-2009, 04:32   #15 (permalink)
Member: 902062
Thanks Meter: 5
is it e250 normal or e250d?
1110 - no ring no sound ombladongsm Nokia Hardware & Hardware Repair 5 04-30-2009 13:16
X600 no ring tone sound??? proxy_gsm Samsung Hardware Repair 0 11-07-2004 16:53
S200 no ring but sound is OK barvik Samsung Hardware Repair 1 10-21-2004 06:01
V300 no ring, no any sound, after I remove securty code CezaricaGSM Smart-Clip 2 07-06-2004 09:54
6100 no ring no vibrate no illumination!!!!!!!! micmac Nokia Hardware & Hardware Repair 11 09-18-2003 10:14
Page generated in 0.23328 seconds with 9 queries
