04-20-2006, 11:05 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 254719 Status: Offline Thanks Meter: 12 | please help d500 white screen solution? |
04-21-2006, 03:38 | #2 (permalink) | |
Insane Poster Join Date: May 2005 Age: 47
Member: 145438 Status: Offline Thanks Meter: 4 | Quote:
04-21-2006, 04:03 | #3 (permalink) | |
Junior Member Join Date: Mar 2006 Age: 38
Member: 251237 Status: Offline Thanks Meter: 0 | Quote:
you chek your phone make call ?? its no hevi porblam its strip porblam you cheng strip my D410 same porblam cheng strip and clear 100% tested solution | |
04-21-2006, 21:06 | #5 (permalink) |
Member: 254719 Status: Offline Thanks Meter: 12 | I noticed that phone cover has mark of fall. And it works strange, when i turn it on display is white, i hear start up sound. When i make call to this phone it sometimes rings sometimes no. When i try ti make a call from it, it sometimes works, sometimes restarts. Is it not only white screen problem Who had this problem? What chip should i replace? I scare to change glued chip. |
04-21-2006, 21:32 | #6 (permalink) | |
Freak Poster Join Date: Oct 2005
Member: 191662 Status: Offline Thanks Meter: 2 | Quote:
POST RESULTS HERE | |
04-21-2006, 22:29 | #7 (permalink) |
Junior Member Join Date: Jan 2006 Location: The Netherlands Age: 39
Member: 221701 Status: Offline Thanks Meter: 0 | problem i had that problem also i changed display and flatcable and new board for the display nothing helps... anny suggestions? plz easy suggestions because i am a new user |
04-23-2006, 15:31 | #10 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | Quote:
05-02-2006, 18:30 | #15 (permalink) |
Freak Poster Join Date: Jul 2004 Location: ***www.meetandmoney.com*** Age: 45
Member: 72109 Status: Offline Thanks Meter: 22 | me also i have d500 with the same problem , i change 03 flex cable, good lcd, flash, cleaning, but no result is thier any solution goodluck |
Please help - wierd screen - d500 - white screen | cduuffo13 | SWIFT Platform | 4 | 01-22-2007 05:47 |
IMPORTANT HELP NEEDED! D500 White Screen | Rowan | SWIFT Platform | 7 | 09-03-2006 12:05 |
D500 white screen please help !!! | pakstar | SWIFT Platform | 3 | 05-02-2006 18:34 |
D500 white screen when switched off. Fine otherwise | Blartiartfast | Samsung Hardware Repair | 5 | 05-23-2005 12:32 |
