Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-03-2014, 13:24   #1 (permalink)
kavithamobiles's Avatar
Member: 1874918
Sonork: 100.1605418
Thanks Meter: 65
Arrow Samsung i9300 safemode problem
IS IT HARDWARE OR SOFTWARE PROBLEM.
Old 04-03-2014, 13:40   #2 (permalink)
Member: 2127758
Thanks Meter: 26
The phone goes into safe mode if u press the "menù" sub key during power...
Restart the phone, and everything will work correctly...
If the phone turns on in safe mode again, it probably has a problem on the menu button...
menù button is the left-bottom key...
Old 04-03-2014, 13:57   #3 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
check the volume down button.
Old 04-03-2014, 14:02   #4 (permalink)
Member: 293299
Thanks Meter: 266
the phone put itself in safe mode to protect itself, it does that when an app is malfunctioning so check any new apps that you may add to the phone.
Old 04-03-2014, 14:11   #5 (permalink)
Member: 1874918
Sonork: 100.1605418
Thanks Meter: 65
Already flash with 4.1.3 and efs repair also done same problem
Old 04-03-2014, 14:48   #6 (permalink)
Member: 2127758
Thanks Meter: 26
Use *#0*# code to test the sub-key
The Following User Says Thank You to Sakalalina For This Useful Post:
Old 04-03-2014, 15:53   #7 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
first check for volume flex if not solves then do this.......... check this.....
http://forum.gsmhosting.com/vbb/f258...emove-1736167/
Page generated in 0.14103 seconds with 8 queries
