samsung gt-s5600 i try to make a upgrade to a samsung gt-s 5600 with the most recent version and i used this S5600XXIE4_Open with the Multiloader 5.56 and all works fine, the soft say that's all OK, i restart the phone and appears a screen in red with this words "exception !!reading CRC... , please wait !!! after appears a second screen with this: page: 1/6 <pick #> S/W version:S5600+XX+IE4 modem:KYRZ213006_05A SHP:VPP R5 2.1.1 built host:SCMSERVANT01 buildat:2009/05/27 14:54:12 ASSERTION_CHECK:FmMountVolume("/System",NULL,FM_ FS_LFS, FM_PARTITION_LFS_C, &iVol) failed. (file OEM\OemBootMgr.c, line 2599) to exit press 0 for 2 seconds then i press the 0 and apears a new screen with a square in blue and with yelow leters " OEMSBL BOot Loader for MSM6288 Uploader ver 5.43 and don't continue please i need help for this i've used the cable of the phone sorry, my englis is bad:D thanks in advance Zeben |
i have try to follow the instructions for this phone that are posted in this forum and show an error that says Download Start Ch[0] Warring : Security fail!! it open four ports COM4 COM9 Warring : Security fail!! COM8 COM10 serial port open error!! i dont know what to do more please help!!!!!!! |
thanks for the help i did it i have my phone working again thanks zeben |
I have the same How you did? Zeben plaese help me |
Which cable for samsung s 5600 and b 3310 |
to "expertlab" sorry for my English i have used the data cable of the phone and have made 6 reset`s to the phone, in each one i take out the battery , important don’t connect the data cable to the phone (to do reset 1-press volume down, camera and the start button at the same time) appears the screen of boot and then you connect the data cable to the phone and you (the multiloader have to have the firmware that you need to download to the phone charged) press download and wait to the end of the process, the phone will restart 3 or 4 times and I hope that all be ok with me it works comps zeben |
Thanks, that's what I needed to enter boot mode, I went into boot yellow not red so I could not do the flash, had erroneous key sequence for entering Donload way ... thanks and my phone works |
on samsung s5600, press volume up+volume down+home and power . select wipe device. |
